![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
Convert Running Lights configuration on an LS ?
On the LS the DRL are the headlights. I have installed some HID foglights on the car but would like to wire the Foglights to come on for DRL and headlights off. Actually I have gotten the Foglights to come on when the DRL mode is active I just can't figure out how to get the headlight DRL mode to go out at the same time ?
![]() ![]() I hate tearing apart a new wiring harness !
1st IPF Supercharged 2011 2LT/RS RJT Convertible
![]() Drives: 2010 LS Camaro CGM 6M Join Date: Jan 2010
How did you install HID headlights on your LS?
I have HID foglights installed as well as HID headlights. First set I got had a burn point in the lamp that was different than the halogen bulb. This is what people talk about aftermarket HID blinding on coming drivers. They went back to the vendor since I don't want to get pulled over. The BFxenon were same burn point as the halogens giving a nice tight focus off the reflectors. No way anyone could tell they aren't factory. I installed myself then had them checked at a local garage for proper focus and aim.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ( . )( . ) Join Date: Feb 2010
HID's are not fans of DRL, because when DRL are on they are running at a lower voltage, and there is a great possibility that you will start see the HID's flicker.
I had them on my FJ Cruiser, and i had to disable DRL to save my ballast's. Anyway, good luck, I personally will be installing some Halo's and (Some how) will be running them as DRL. |
Drives: Camaro Join Date: May 2009
Our kits are digital, 35w, and very stable... we have not had any issues with the DRLs.
Same with the FJ cruisers!
#6 |
The HID ballast is not powered off of the DRL voltage. The DRL voltage is just a trigger for a 12v relay which switches power to the ballast. Because of this the ballast should not drop in voltage causing a flicker. With proper power and grounding for the ballast the system should function properly.
This BFXenon system has met all my expectation and has kept the old school look to my camaro ! Sorry halo guys !
#7 |
probably is, i was just commenting on my own experience with my FJ Cruiser, i had a lot of flickering when i had DRL on, after i disabled them, all was good, my cousin also had the same issues with his 07 Silverado, and i told him to disable the DRL and problem solved.
but then again, it might be that the quality of the ballast was not very good. i guess ill know when i buy my HID's |
#8 |
OCD
Drives: 2014 2SS/RS 1LE Join Date: Oct 2009
Installed my HIDs over the weekend and this morning I noticed when I backed out of the garage and the headlights switched over to DRLs the HIDs started flickering and after a minute or so just kicked out. When I turned them back on as headlights they came back on so they didnt blow a fuse but they are definitely flickering and dying out when they switch to DRL. Anyone have any ideas how to fix this?
#9 |
![]() ![]() ![]() Drives: 2023 2SS Convertible Join Date: May 2009
You need to go to Radio shack and get some 12 Volt Relays. Wire up the low beam signal to the trigger, and then wire a 12V hot lead to the relay to run the lamp. Make sure they are high current relays, because the HID's usually make a big spike in current when they start up. Steady state is lower, but they need a pretty good hit to get started.
Until then, make sure you put your lights on or you will fry your HID's when they are trying to run on low voltage. -Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold! '23 2SS Convertible -Same as above except orange. |
#10 |
Don't know what kit you are using but the DRL voltage is pulse width modulated to get to a lower voltage when the drls are suppose to be on. I am driving my fog lights off this trigger an had to put a 10uf cap from the trigger to ground and a diode in line of the trigger to protect the cars computer which does the pulse width modulation. If you don't do this even using a relay may result in the same flickering and a chatter from the relay.
I'm surprised that the HID headlight relay in your system doesn't have this built in? I would call the manufacturer before playing with the circuit.
#11 |
Scout Sniping
so did we figure out how to make the headlights not come on unless its night time?
Eric
Previous Car:1SS/CGM 6MT w/ Sunroof & FACTORY BLUETOOTH!!!: New Era OTR, Steeda Short Shifter, Ported TB, Stg 2 ported intake manifold, Fasterproms, Poor man down pipes, MBRP 3" Exhaust!!! Now I drive a F150 Supercrew |
#12 |
![]() Drives: Black 2010 Camaro 1LT Automatic Join Date: Feb 2012
Convert fog lights
Hey, I saw your question. I have the same question. I too would like to wire the Foglights to come on for DRL and have the headlights off. If you can help me I'd appreciate it. I have a 2010 1LT non RS model.
| Angel Eye Mod (93-97 Camaros) | CamaroSpike23 | 4th Generation Camaros | 105 | 05-12-2014 03:17 PM |
| FOG LIGHTS ON RS | blueforza | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 17 | 04-17-2011 07:04 PM |
| Halo Lights & Driving Lights | 87irocz | 5th Gen Camaro SS LS LT General Discussions | 34 | 02-01-2011 09:04 AM |
| Day Running Lights | trudawg660 | 5th Gen Camaro SS LS LT General Discussions | 15 | 04-07-2009 12:34 PM |
| LED tails, running lights | mondain | Cosmetics and Lighting Modification Discussions | 13 | 02-16-2009 02:39 PM |
