Old 01-29-2025, 12:42 PM   #1
MSgt O
MSgt O's Avatar
Drives: 2012 Camaro 2SS/RS Vert LS3/M6
3.5 DSS aluminum Drive shaft question
Rear Subframe/Cradle Lock-out kit MUST BE INSTALLED on the vehicle PRIOR to installing a Driveshaft Shop 1-Piece Driveshaft
What does this entail or mean?
MSgt O is offline   Reply With Quote
Old 01-29-2025, 12:54 PM   #2
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
I have a one piece DSS shaft and did not use a Cradle lock out kit. I believe I may have read something about that regarding the Gen 6 Camaro. Unless they are doing something way different now, you should be fine bolting it in.
HOJO is offline   Reply With Quote
Old 01-29-2025, 01:51 PM   #3
MSgt O
MSgt O's Avatar
OK thanks! Do you have a manual or auto, and im not sure why that would matter..but figure I better ask
Old 01-29-2025, 05:45 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
News to me as well! We didn't do anything like that on my install... It wasn't even mentioned in the install instructions.
Old 01-29-2025, 08:12 PM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Mine either. I have a manual trans.
Old 01-29-2025, 08:21 PM   #6
MSgt O
MSgt O's Avatar
huh the phasetek wedsite specifies it...but I trust you all. Thanks!!
https://www.phastekperformance.com/D...Buy3glUc9mdtyz
Old 01-30-2025, 08:29 AM   #7
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I believe they are trying to limit the amount of movement as the one piece doesn't have as much give as the 2 piece. As a daily diver that isn't driven hard probably would never have an issue.
In my opinion cradle mounts are an absolute must in these cars no matter the type of use.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 01-30-2025, 10:05 AM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
What Joe said. When you install one of these, at least mine does, the TQ that is delivered to the rear is a massive difference than what the stock DS delivered, it's like twice as much, and INSTANT! No lag, so yeah like most of us have done, solid cradle mounts are a must to limit the cradle movement and not mess up the DS couplings/joints. Hers's a cool vid showing what I'm talking about. Enjoy!
Old 01-30-2025, 11:39 AM   #9
MSgt O
MSgt O's Avatar
Very cool video and makes total sense! Thanks guys. Another thing to add to the list of things to do once it warms up some!
Old 01-30-2025, 12:10 PM   #10
HOJO
HOJO's Avatar
I am a manual. Some use solid mounts, some do not. I do not and have a twin turbo set up with 648 whp and a ZL1 diff and axels. All depends on how hard you want to drive it.
Old 01-30-2025, 06:15 PM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
That too. You don't really need solid mounts, but if you drive your Camaro hard a lot, ya might want to. Plus if you do install the solids, expect some increased NVH..
