Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Members Area > Ask the Camaro Team
Old 01-31-2025, 08:55 PM   #1
CamarOklahoma
Drives: Lt1
Battery Corrosion (Neg Terminal only) help
I been struggling with figuring out what's going on with my electrical, I cleaned off the corrosion and used corrosion prevention but now it's returned. Seems to be only on the negative terminal and on the small gauge wire. I have a yellow top battery by optima. Today while sitting idle the radio turned off.
Can anyone help me figure out my next step ?
CamarOklahoma is offline   Reply With Quote
Old 01-31-2025, 09:22 PM   #2
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Terminal is leaking.. probably cracked plastic.
Neutralize with hot water / baking soda solution, sprinkle area w corn starch / baby powder and see if it returns. Baby powder should help track the leak.
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs.
http://www.motorsportsne.com/
Vtor_ZL1 is offline   Reply With Quote
Old 02-01-2025, 10:07 AM   #3
CamarOklahoma
Drives: Lt1
Thanx, I'm also think my voltage regulator is going out, voltage was at 15 and 15.2 for a few days. As of right now it's at 12 but jumps to 14 at times but can't determine when it raises throughout the day
Old 02-01-2025, 11:36 AM   #4
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
It's temperature / load based, so it will bounce around. 15 is probably high end. I'd bet that terminal was over torqued and plastic cracked.
ing for grip.
Old 02-01-2025, 02:41 PM   #5
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
It is in normal voltage area.
Old 02-02-2025, 09:37 AM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Here is some good info for you on our charging systems..
https://www.camaro5.com/forums/showthread.php?t=245282
Old 02-03-2025, 01:19 PM   #7
CamarOklahoma
Drives: Lt1
Thanx for the help and info, I'm always on a trial and error basis with my vehicle. I never thought about the actual terminal post being torqued. I can see now how I have done it, my terminals have the ridiculous t bolts, I don't like them because if I wanted to add a shim, there's no room for the t bolt to clamp a grip underneath. Well I'm gonna probably get a new b with a warranty this time.
Thanx again, Im proactive on any problems I face, at times it's the last thing before sleep and the first thing when I wake. I guess it keeps me young but at some point I'd like a vacation from problem solving
