Old 03-27-2025, 11:53 AM   #1
Leased_SS
Drives: Chevy Camaro SS
Idle Surge after cam install 2012 Camaro SS
I installed a BTR Stage 2 V2 cam on my Auto 2012 Camaro SS (ls3 not l99 so no VVT AFM DOD). New Delphi LS7 lifters, 5/16 hardened pushrods 7.425', dual valve springs.
Just fired it up and this is what it sounds like any thoughts on what it could be?
https://youtube.com/shorts/uF7tPG9rOfQ
https://youtube.com/shorts/jX5B_VgyoYM
Leased_SS is offline   Reply With Quote
Old 03-28-2025, 08:25 AM   #2
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Well - it's going to need to be tuned before it's going to idle properly. However, you may have more going on than that. It's hard to tell from the video, but it almost sounds like it's only running on 4 cylinders. This is more common than you might think - it's very easy to get the ignition coil harness flipped, and essentially have the wrong firing order. Typically you'll get some back-fires through the intake when you do this, but I have heard/seen where they will start and run, they just sound fun. So, I would make sure you don't have one bank running cold - if you do, then I would start by checking that as it is an easy, commonly made mistake.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 03-28-2025, 11:19 AM   #3
RedTexasSS
Drives: 2012 SS Red w/ black rally stripes
If it's running on 4 cylinders I would check the grounds. I recall seeing this after a friend's cam install. There was a ground wire, I believe on the rear of the right cylinder head that was damaged during the cam swap and the injectors on one side were not working. Good luck.
2012 SS Camaro, Victory Red w/black rally stripes, SLP front splitter, ZL1 Rocker panels, ZL1 Add-ons Stealth Wickerbill, L99, Magnuson Heartbeat supercharger, 65 lb. injectors, 87 mm pulley, ZL1 fuel pump, ADM FPCM,1 7/8 Texas Speed long tube headers, v-max ported throttle body, Rotofab cold air intake with Apex scoop, Apex catch can, MSD plug wires, AEM AFR and Boost gauges, GPI SS1 VVT Cam, HP tuners with remote tune by Ryan at GPI, Solo axleback exhaust w/j pipes and stock resonator.
RedTexasSS is offline   Reply With Quote
Old 03-28-2025, 03:44 PM   #4
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
My car sounded similar to this when I did the coil pack relocation & hooked up 2,4,6,8 backwards.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 03-28-2025, 04:08 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Hey Andrew! Good to see you back in action!! Missed you brother! I hope all is well with you..
Old 03-28-2025, 04:52 PM   #6
acammer
acammer's Avatar
Doing good - just staying SUPER busy. I really like coming on here, I just don't have the time for it. I pop in when I can!
Old 03-28-2025, 11:22 PM   #7
Leased_SS
Update: I was able to fix this issue.
Reason: I never replaced the intake manifold gaskets (idk why) so I pulled them off and bought some new ones, runs good now, it does have a base tune from cordes performance in AZ to get it up and running.
Possible reasons I fixed as well: When I put the motor back together I forgot to add 2 grounds that were on it before, could have impacted the way it ran as well
Old 03-29-2025, 05:35 AM   #8
acutron42
acutron42's Avatar
Glad you got it fixed! I would guess it was the grounds & great advice by RedTexasSS to point those out. I have heard of people reusing intake gaskets but glad to see that you changed them also. Post another video if you can!
Old 03-30-2025, 10:07 AM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Awesome my friend! Stay well!! And busy is good!!
Old 03-30-2025, 10:09 AM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Awesome sir! Glad you got it all fixed up. Enjoy it..
