Old 04-11-2025, 04:30 PM   #1
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
Brembos are squealing....
Replaced my front and rear Brembo rotors/pads with zinc plated Detroit Axle rotors on all 4 corners along with Hawks Performance Ceramic pads as well. No issues since Mid Feburary with this setup... and now all of a sudden I get a loud squeal at slow stops. Is it my pads that is glazing over and I need to remove and them down? Or is it something else? It is embarrassing.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 04-12-2025, 07:38 AM   #2
FASTFATBOY
Drives: 2013 ZL1
Pull the pads back off and put high temp anti seize on the back of the pad where it touches anything.
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
FASTFATBOY is offline   Reply With Quote
Old 04-12-2025, 09:34 AM   #3
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
have you tried bedding the brakes?
Old 04-12-2025, 04:09 PM   #4
SummitWhite11
Drives: 2010 2LT/RS
I did that with the supplied packet from Hawks Performance for the rear. When I ordered the front pads.. it did not come with a packet. I used SIL-GLYDE instead. Perhaps that's where the problem is? I'll have to take it off and do what you said.
2010 2LT/RS
Old 04-12-2025, 04:10 PM   #5
SummitWhite11
Drives: 2010 2LT/RS
I did that Mid Feb... until now its a problem. I'll do that again when I remove the front pads and get the high temp lubricant on it then go from there.
2010 2LT/RS
Old 04-12-2025, 06:14 PM   #6
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
SIL-GLYDE is to thin in my opinion to be used on the back of the pads, Use a caliper grease or one of the permatex types which is more like what the hawks product was. No sense in re bedding pads unless you scuff up the rotors and pads, the material is already built into the rotor.
Lastly the Detroit rotors are not the best quality I have put them on my commuter cars a few times and they have never lasted long.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 04-12-2025, 07:04 PM   #7
SummitWhite11
Drives: 2010 2LT/RS
Good to know about the SIL GLYDE..as for the Detroit Axle Rotors... I have heard and read good reviews on them which was why I purchased.
2010 2LT/RS
Old 04-15-2025, 12:37 PM   #8
SummitWhite11
Drives: 2010 2LT/RS
Update: I removed the front pads and added a good coat of CRC Brake Disc Quiet lubricant... I read that it handles high temps.... Did the bedding procedure... then drove it across town to do some errands. All was quiet... then as I started getting closer to home.. it started squealing again at around 14 mph and slower stops.
I then removed the rear pads and added a good coat on both sides again... then did the bedding procedure... it was quiet for the first few minutes then the squealing started again at around 14mph and slower stops.
Whats happening here?
2010 2LT/RS
Old 04-15-2025, 06:28 PM   #9
Joe.G
Joe.G's Avatar
Bedding does nothing after the pads and rotors have been used, Bedding needs to be done when first installed. That is not likely your noise issue any way. Its hard to say with out looking at them in person but there is a good chance they may never be quiet with the low quality rotors.
Old 04-15-2025, 06:58 PM   #10
SummitWhite11
Drives: 2010 2LT/RS
Sad to hear that... I read nothing but good reviews... I sent Detroit Axle a message about my issue and waiting for a response. If worse comes to worse... Can I resuse my Hawks pads on "Brembo" rotors... or is it too late for that?
2010 2LT/RS
Old 04-15-2025, 07:11 PM   #11
Joe.G
Joe.G's Avatar
You could reuse the rotors, was the rotor mounting surface and hub surface clean? You could try taking everything apart and clean it up and remount, there's no harm in trying the Hawk pads should be quite as they are not their race spec pads.
Old 04-15-2025, 07:29 PM   #12
SummitWhite11
Drives: 2010 2LT/RS
Yes, the rotors and mounting surface are clean. What I meant was.. if the Detroit rotors are defective and if I was to order "Brembo" rotors... and reuse my Hawks pads... are the pads still reusable... or do I need to sand them down?
2010 2LT/RS
Old 04-15-2025, 08:40 PM   #13
Joe.G
Joe.G's Avatar
You should be fine to run them on the new rotor, you would need to rebed the new rotors. When you bed the brakes you are putting pad material onto the rotor, this help with. Braking.
Old 04-15-2025, 08:44 PM   #14
SummitWhite11
Drives: 2010 2LT/RS
Thanks for that info. Once I have an answer from Detroit Axle... good or not... I will get new rotors and go from there.
2010 2LT/RS
