Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Members Area > Site Related Announcements / Suggestions / Feedback / Questions
Old 04-18-2025, 09:31 AM   #1
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Tapatalk not finding Camaro5
I've been using Tapatalk for years, mostly for this forum, but it seems to have dropped Camaro5 and can't find it again.
Any suggestions on a fix or a different Android app that would work?
Thanks,
Larry
Old 04-18-2025, 12:47 PM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Drives: 2020 2SS - A10, NPP, MRC, CAI
This board is overrun with BOTS, the "Session" table is full continuously not allowing any new sessions (if you have a cookie for the site you can still get on)...
I run a vBulletin forum and ran into the same problem last month, I increased my max table size from 16M to 64M but I also added the following code to my hourly and half hourly cleanup files to delete "guest" sessions (i.e. the BOT sessions), haven't had a problem since...
Code:
$vbulletin->db->query_write("
	DELETE FROM " . TABLE_PREFIX . "session
	WHERE lastactivity < " . intval(TIMENOW - 600) . " AND userid = 0
HINT to the site moderators... You are getting a bunch of vBulletin Database Errors because your session table is full, adding the above code to your "includes/cron/cleanup.php" and "includes/cron/cleanup2.php" will solve your problem...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Fender Badge, Footwell Lighting
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB
Left: My "fun" ride (475 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate...
2SS Capt is offline   Reply With Quote
Old 04-20-2025, 02:15 AM   #3
2SS Capt
2SS Capt's Avatar
Code:
Hey Admin/Mods... "You're welcome..." (didn't even get an acknowledgement for giving them the fix for their issue) (At least the board is down to around 3,000 "visitors" vs. the 48,000 previously that was locking up the site...) Now the site at least works, which was my goal...
Old 04-20-2025, 08:11 PM   #4
larry_g
larry_g's Avatar
Nice, but Tapatalk still can't find the site
Old 04-24-2025, 06:36 AM   #5
larry_g
larry_g's Avatar
And today it magically reappeared.
Sent from my Pixel 8 Pro using Tapatalk
