Old 04-26-2025, 11:10 PM   #1
void_kp
void_kp's Avatar
Drives: Chevrolet Camaro Z28 (2015)
can 315 fit into stock rims and wheel arch?
hey folks,
I 305 is nice, but with added horsepower and torque some more rubber sometimes would be nice. I was wondering if there's a wider tire that can fit on standard wheels and standard ride height on the z28?
2015 Red Z/28.
Seattle area
void_kp is offline   Reply With Quote
Old 04-27-2025, 07:30 AM   #2
4 FN 27
Drives: 2015 Z28
https://www.camaro5.com/forums/showthread.php?t=626039
This might be a little help.
"Resale value is my beneficiaries problem...unless they can bury my in my Z...problem solved."
4 FN 27 is offline   Reply With Quote
Old 04-27-2025, 10:46 AM   #3
Coz3z3
Drives: 2015 Z/28, 2015 1LE
Yes. I have run the Falken Rt660 and currently running Continental Extreme in 315/30-19 with no issues. Stock height and stock wheels
Coz3z3 is offline   Reply With Quote
Old 04-27-2025, 01:34 PM   #4
highrevving
highrevving's Avatar
Drives: Z/28
Running PS4 325 rears on stock setup with no issues.
highrevving is offline   Reply With Quote
Old 04-27-2025, 02:31 PM   #5
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
Stock setup (suspension and wheel well) sure. Stock 9.5" wide wheel, I would not.
Personally, I have...
285/35/20 on 20x10's
315/35/20 oon 20x11's
That's on stock suspension and it's fine, but starting next weekend I'm installing a bunch of BMR stuff and Pedders coilovers. Planning to drop probably 1.25". Should not be any clearance issue.
One thing you'll likely need to do is zip tie back your parking brake cables. I had to do that at stock height and expect even more so lowered.
SS_Dave is offline   Reply With Quote
Old 04-28-2025, 12:58 AM   #6
spyderbuddy
been runing275/40/20's on the front
and 315/ 35/20's on the back for couple of Years
On the stock Rims Rs Midnight Silver 20's
Was and has been told it does't not work
Looks like it works to me and just maybe some of these gentlemen don't know everthing
Running Vemon Power 275' on front
Running vemon Power 315' on Back
both are Ragnorok GTS ZR rated Tires
Old 04-28-2025, 06:19 AM   #7
ariZona28
Give speed a chance
ariZona28's Avatar
Z/28s have 11×19 (F) and 11.5 x19 (R). 315s shouldn't be a problem.
ariZona28 is offline   Reply With Quote
Old 04-28-2025, 06:52 AM   #8
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
He is talking about Z/28 rims, you should be fine.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 04-28-2025, 11:10 AM   #9
void_kp
void_kp's Avatar
thanks folks, I was also not pushing for 20". rotating mass is a big deal on track, unless I want to spend a ton of money on VERY light 20" rims, there's no advantage to move to 20.
2015 Red Z/28.
Seattle area
Old 04-28-2025, 03:40 PM   #10
aris
Drives: Z/28
Yes - you can fit 315 on stock wheels. I have run Cup 2 as well at RT660 in 315 with no issues.
aris is offline   Reply With Quote
Old 04-28-2025, 04:44 PM   #11
The SS Godfather
The SS Godfather's Avatar
Drives: TBS BLOWN/CAMMED 2010 CAMARO RS/SS
Yep, 265 front , 315 rears...22" loving it !!
The SS Godfather is offline   Reply With Quote
Old 04-29-2025, 10:03 AM   #12
IdahoRob
Drives: 2014 Z28
I'm running 315 sport cup 2's front and back. Stock everything and have tracked with these 315's and no issues at all. I'm not sure why non-Z28 members are supplying info about their cars?
IdahoRob is offline   Reply With Quote
Old 04-29-2025, 12:07 PM   #13
void_kp
void_kp's Avatar
ahahah totally.
I've asked about stock rims and we got 20" , people without a z/28 , non symmetrical setups ... this is the joy of the internet
I should have posted something like:
"Hey, I've tracked the z/28 with a square 315/30/19 setup and rubber keeps hitting the wheel arch, this is a stupid setup!"
and let everyone go crazy on replies to educate me on the fact that 315 is actually a viable setup
I would have had my answer anyway and I would also had some fun
2015 Red Z/28.
Seattle area
Old 04-29-2025, 03:16 PM   #14
highrevving
Drives: Z/28
I'm glad the community is helpful especially since Camaro has ended production.
