Old 05-06-2025, 12:26 AM   #1
econ
Drives: 2013 2ss
Service Power Steering light came on. I have a few questions.
I know exactly why it came on. Not worried about that.
But, my question is, can this lead to a "reduced engine power" situation?
Or "Limp Mode?"
Or is this ONLY going to be a steering issue and the annoyance of the light and warning on the display?
econ is offline   Reply With Quote
Old 05-11-2025, 12:20 AM   #2
econ
Drives: 2013 2ss
Anyone out there?
Is there a known list of things that trigger the "reduced engine power" mode that I can look over and review?
Old 05-11-2025, 01:39 PM   #3
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Battery health is where I would start, These cars really do not like a aging weak one and can cause the issues you are describing.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 05-12-2025, 12:02 AM   #4
econ
Drives: 2013 2ss
I'm looking for a comprehensive list of things that would prompt a "reduced engine power" condition.
Old 05-12-2025, 08:02 AM   #5
Joe.G
Joe.G's Avatar
I am unaware of a list anywhere, but it's almost as if it's a safe mode so multiple things could cause it, misfires could cause it, low fuel pressure and so on.
Old 05-12-2025, 08:31 AM   #6
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
MIL light on? Did you check for codes?
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 05-12-2025, 10:16 AM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
This ^^^ I have had an instance before where my MIL light didn't come on, but had an issue that DID set some codes without setting the light. Also you might want to fix what you say caused it..
Old 05-12-2025, 10:24 AM   #8
Joe.G
Joe.G's Avatar
Hooking a scan tool up should be done with or without a check engine light, having someone that knows how to use one properly helps as well in diagnosing issues.
Old 05-12-2025, 11:39 AM   #9
gtstorey
And it needs to be checked with a scanner that can read all of the modules, not just the P-code engine module.
Old 05-12-2025, 11:46 AM   #10
ariZona28
Give speed a chance
ariZona28's Avatar
This:
ariZona28 is offline   Reply With Quote
Old 05-12-2025, 11:49 AM   #11
Joe.G
Joe.G's Avatar
Well that would do it as well.
Old 05-12-2025, 11:53 AM   #12
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
Here is one example. As for a comprehensive list why bother unless you have a dtc associated with that condition first.
PIP4578B
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 05-12-2025, 03:56 PM   #13
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Originally Posted by ariZona28 View Post
This:
Yep, we tried to tell him! That's what happens when you DON'T believe what the knowledgeable folks try to tell ya. Never second guess the great info we have on the forum!
Old 05-16-2025, 12:32 AM   #14
econ
Drives: 2013 2ss
No MIL light.
But I do have 1 code....U0109.....Lost communication with fuel pump control module.
With key on engine off, I get the "service power steering" light.
