Old 06-18-2025, 12:38 AM   #1
econ
Drives: 2013 2ss
Thinking about turning my Gen 5 Camaro into a race only car
Not seeking a comprehensive list of specific how-to information here. Too much for one thread.
But I do have some general questions.
My general plans are.....
---To keep the power train as is, stock. Stock injectors.
---Dump the CAN network, all factory control modules
---Use a stand-alone ECU to run the engine
---Throttle cable conversion (maybe, looks like a better way to go)
I will gladly and willingly loose headlights, brake lights, turn signals, radio, instrument cluster, heater, AC, power steering.....all that stuff. This is a direction I am thinking about going.
Now, my question is this?
What do I do about the fuel pump? Cooling fans? Starting the engine? What happens to anti lock brakes? How do I open the trunk?
The car....
2013 Camaro 2SS, LS3, 6 speed manual
Thanks!
Only ever done this with a carb'd engine and OBD1 engine. Never CAN.....
econ is offline   Reply With Quote
Old 06-18-2025, 01:01 AM   #2
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
Why would you do all that and keep the stock power train? Seems extremely pointless to me.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 06-18-2025, 05:40 AM   #3
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
That would be a complete waste of time & money. If your goal was an 8 or 9 second pass at the drag strip with a ton of power that is a different story. If you want to build a "race only" car look at sites like copart. You can probaly find a stripped/recovered theft salvage car for under a grand.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 06-18-2025, 08:58 AM   #4
gtstorey
Start with what kind of race car. Road or drag racing?
I don't think you will find anything on copart that can be made drivable for under a grand. To many "LS Breaker" around. Might something under $10k though.
First step is making sure you have access to the full wiring diagrams for the car. But I don't know that going full aftermarket ecu is necessary. And I don't know that it will be possible if you want to keep the antilock brakes.
Fuel system would probably need to have an aftermarket regulator installed.
Powering/controlling the fuel pump, fans and staring would be handled by the aftermarket ecu and relays. Trunk would need to be studied, I don't know if that is a module at the trunk latch or can be directly powered by +12v or ground. Same with door latches.
Old 06-18-2025, 09:27 AM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Total waste of money and time I think, and you would be destroying a nice 5th gen. If you want o build a "race car", find yourself something that you can fix up for a lot cheaper, and easier.
Old 06-18-2025, 09:51 AM   #6
acutron42
acutron42's Avatar
Yeah GT, a grand is light lol. I was looking at a salvaged 3.6 not thinking lol.
Old 06-18-2025, 05:07 PM   #7
redcoats1976
If youre going to gut all the computers and drivetrain anyway,a V6 car is as good a start as any.
Old 06-18-2025, 09:30 PM   #8
econ
Drives: 2013 2ss
Trying to focus more on the "how" than the "why," but if you consider the "why" of it all to be useful information, I will share.
I am having issues with the can. The cost of the dealer fixing said issues is equal to the cost of a Holly Terminator or Dominator set up (about $2K).
So, which direction to go? The stock power train will suffice for my off-road activities (it's required in some cases), so for now, the stock power train stays. With the Holly stand alone, it will easily support any changes that I may want to make down the road. So, the stand alone makes more sense from my stand point.
True, I could stick with the factory CAN set up, and run it, but then it will be costly (about $2K) and I am stuck with a set up that I can not easily maintain long term. I don't know about you, but working on the CAN is not something I am tooled up to do and it's a little over my head. The Holley on the other hand is very DIY friendly.
Old 06-18-2025, 09:34 PM   #9
econ
Drives: 2013 2ss
See post #8.
I would be perfectly content with the stock performance for my off road activities. Not looking for a "shell" to start from scratch.
Simply trying to go stand alone. Not sure about a few things though...
Old 06-18-2025, 09:42 PM   #10
econ
Drives: 2013 2ss
I have my eye on the OEM service manual. The 4 volume set.
I am not intent on keeping the anti lock brakes. I am simply wondering what to do about them if the CAN is no longer operational. There is a module with 4 lines going to it. Just leave it? Replace it with something? Just thinking out loud as I ponder what I am up against.
So fuel pump, fans, starter are all handled by the ECU such as the Holley Dominator or Terminator?
I would prefer a throttle cable as well....Anyone here use a throttle cable?
Old 06-18-2025, 09:45 PM   #11
econ
Drives: 2013 2ss
The thing about the stand alone kits is that they are very DIY friendly.
Not worried about time, money and destroying a 5th gen. Just trying to go stand alone, get rid of the CAN, have an easy to work on car that I can toy with at the track. The car itself is a toy.
Old 06-18-2025, 09:46 PM   #12
econ
Drives: 2013 2ss
Keeping the power train, gutting the CAN, going stand alone
Old 06-18-2025, 09:49 PM   #13
econ
Drives: 2013 2ss
So I will loose, windshield wipers, lights, windows that go up and down, cluster, gauges, horn, turn signals. Thats fine.
But I will have to figure out doors and trunk.
Old 06-19-2025, 05:43 AM   #14
acutron42
acutron42's Avatar
Thank you for the explanations, this helps to get you the anserwers you seek. Is this car going to be track only & not inspected to your state emmisions requirements? I am assuming so as you wont need turn signals.
