![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2LT/RS Join Date: Mar 2015
Billet Aluminum Battery Terminal cover
Curious for those who have installed this cover... how do you like it? I just ordered one off of Amazon for about $40 with free shipping compared to the major vendors that sell them for much more plus shipping on this site or elsewhere etc... The reason I replaced mine was that the factory plastic cap with the strap broke. Upon looking for a new factory replacement.. I kept seeing these red plastic cover/cap go for upwards of $60-$90 on line. WTF! Anyhow I installed it but then realized that this cover needs to be removed every time I want to hook my Camaro to the battery tender in the garage when not in use. The cover comes with some 3M double sided tape... but what for? If I need to remove it then it just makes it harder. I chose not to apply the 3m double sided tape. It's too bad it doesn't come with a cap that can screw on and off. Thoughts??
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can. Last edited by SummitWhite11; 08-08-2025 at 06:52 PM. |
#2 | |
![]() Drives: TBS BLOWN/CAMMED 2010 CAMARO RS/SS Join Date: Jul 2021
#3 | |
Are you referring to the rear trunk battery hook up?
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can. |
#5 | |
The thing for me is I bring my Camaro into the garage forward facing in which the battery tender is hooked up in front. I do not have any electrical outlets on my side walls in the garage which is a problem. I plan on having them installed in the future by an electrician but for now this will do. As for backing in the Camaro... that is another option... but it is a hassle in having to remove the rear trunk floor cover over the battery to hook up and reinstall everything when on the go. That is a major PITA if you ask me. Post pics of your set up if you don't mind.
2010 2LT/RS
#6 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Mine is hooked to rear battery with the ends that bolt to battery not the clips, I then snaked it up from under the floor and all i have to do is pop the trunk and plug it in, I gently set the trunk down and I am done. It is not in the way of anything and barely noticable when you open the trunk as it is against the back wall.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
#7 |
I do this as well... I have the CTEK 7002 charger. Works great..
#8 |
Please post pics guys so I have a better understanding of what I am looking at. My terminal hook up line is rather short when it connects to the extension for the battery tender.. Pics of what I am currently doing below....
2010 2LT/RS
#9 |
![]() Drives: 2013 ZL1 Join Date: Sep 2021
You can either buy outdoor rated velcro or glue some rare earth magnets to the cover-easy on easy off.
#10 | |
I am not following sorry.
2010 2LT/RS
#11 |
I would not hook it there go strait to the battery, I'll try to get Pictures this week as I am away at the moment.
I use these to the Battery https://www.batterytender.com/produc...ccessory-cable
#12 | |
I've been doing this for 6 years with no issues. Looking for to the pics.
2010 2LT/RS
#13 |
I'll post pics of my set up once I am back from vacation. Just wanted to show you the wires I use instead of the clips. Takes me about 10 seconds to hook up after opening car door.
#14 |
I found a set up I don’t remember where at but it comes through the trunk floor with a grommet and goes to the battery, there is a cap on the part that sticks out so I don’t even have to open the trunk.
Orange Krush II
