Old 08-10-2025, 03:42 PM   #1
hplsromantic_90@yahoo.com
Drives: 2010 Camaro 2LT
V6 Transmission install
Swapped out the clutch, flywheel, pressure plate and slave cylinder/throwought bearing. I am REALLY struggling to get this transmission to go back into its home. I can get it to line up on the bottom but the top refuses to marry up to the engine. Any tips or tricks?
hplsromantic_90@yahoo.com is offline   Reply With Quote
Old 08-10-2025, 03:56 PM   #2
I realize I did not provide enough information. It’s a 2010 v6 6 speed manual.
Old 08-10-2025, 06:29 PM   #3
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
Always good to see another 2010 2LT on the forum!... I wish i could help but I am running a 2010 2LT auto. I hope someone chimes in with good useful info that may assist you to get it running again.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 08-11-2025, 07:46 PM   #4
bsn
Drives: 2013 ZL1
Did you use a plastic alignment tool to line up your clutch? If you did they can have some slop so sometimes its a matter of unbolt and re-align the clutch until it slides in. You can buy a good quality metal stepped universal aligner that works much better but its kind of pricey for one time use. Transmission shops often use a cutoff input shaft from a junk transmission, that is the best.
bsn is offline   Reply With Quote
Old 08-12-2025, 01:44 PM   #5
I took the clutch off today and peered in and noticed the slight slop using the plastic tool. Re did everything and made sure to look at the alignment of it all before attempting the trans again. Noticeable difference however I still can’t get it to slide on the last half inch. All the bolt holes line up and I can even start threading them but I’ve been led to believe to never use the bolts when mounting the trans. Anybody else hear this?
Old 08-12-2025, 06:53 PM   #6
mr_honez
Wifey Lover
mr_honez's Avatar
Drives: 2013 2LT to 2SS Manual Conversion
Is it a half inch all the way around? Did you put a dab of lube on the pilot bearing? is the trans in neutral? To me it sounds like the shaft splines are misaligned with the clutch plate or the pilot tip is getting stuck on the outside of the pilot bearing.
mr_honez is offline   Reply With Quote
Old 08-13-2025, 08:05 AM   #7
fz4k98
Drives: 2013 1ss
I have found that making sure the transmission gap to the engine is consistent all the way around the bellhousing when sliding it forward helps a lot. if the gap is less at bottom for example the transmission at rear is too low, gap smaller on right side, transmission rear needs to go left.
Clutch alignment tool used,
film of grease on input shaft splines and tip that goes into pilot bearing,
transmission going in at angle to match engine angle.
I have a v8 but assume it should be the same for yours.
fz4k98 is offline   Reply With Quote
Old 08-16-2025, 07:57 AM   #8
Just an update, I finally got it in. Bad news: I had to do it twice.
I took off the clutch and pressure plate and peered down the hole until everything was lined up with my eyeballs(kind of a feat with that little room to work with. My jack stands don’t go high enough for the trans to come out from under the car). After that everything went in relatively easily. Refilled fluids, bled clutch, bled brakes (since I was already there). Could never get the clutch to feel correct though. I noticed as I was putting the car in gear the wheels would instantly start spinning. Obviously that wasn’t correct.
This led me to a different post on here with very similar symptoms to what I was experiencing. Bottom line, clutch was installed backwards.
The manual that the both of us used used a word description rather than a graphical depiction that leads you to putting it in backwards. The description they used seemed to conflict with videos online on which side of the clutch faces the transmission. So I had the wonderful experience and learning opportunity to do it all again.
In the end I got it all good and now everything is back to normal. Biggest takeaway: don’t single source your information for tackling a project like this. I was using the manuals from “operation CHARM” online and for the most part they do a great job. Had I more seriously considered multiple sources of information I may have been able to save myself some heartache and general body aches.
Hopefully this will potentially help somebody in the future, especially because there is no such thing as a detailed write up for how to tackle this project for our (V6 MT) cars.
