Old 08-18-2025, 09:25 PM   #1
AnythingButTime
Drives: 2015 Z28
Brembo Replacement Brake Pads
Apologies as this has been discussed before...but my lack of knowledge about Carbon Ceramics has me concerned I am going to buy the correct size pad for the wrong application and ruin my rotors.
From past posts I believe I am correct in saying that the Brembo replacement pads are as follows:
Front pads - 22990624 - Brembo P10096N
Rear pads - 22990625 - Brembo P85110N or P85116N
My first questions is, the two versions of rears are shown to be oe compatible, but one has 17mm of material the other 18mm. Which do I want?
Next, the Brembo site shows them in the parts list, but clicking buy now does not show them available. A quick google shows all the regular auto parts stores being able to provide them...but the prices... $115 for the fronts and $85 for the rears seems out of the range of what I expect...which makes me think I'm not ordering the correct pad application. Thoughts?
AnythingButTime is offline   Reply With Quote
Old 08-23-2025, 08:13 PM   #2
Gouki
Drives: 2014 Z/28
https://www.camaro5.com/forums/showthread.php?t=633660
All the details are here, it'll be about $1k+ for a set of pads
Gouki is offline   Reply With Quote
Old 08-23-2025, 09:57 PM   #3
AnythingButTime
Drives: 2015 Z28
$1000 would be what I am expecting. That post is where I collected my original information. I see your previous post, those part numbers aren't getting me anywhere.
Old 08-27-2025, 07:09 AM   #4
johna
Drives: 2015 White Z28
As another option, you can replace your original rotors and pads. I took mine off at 7000 miles to keep them in good condition for the next owner (if that ever happens) and went with the girodisc.
https://girodisc.com/chevrolet-camar...ce=chatgpt.com
johna is offline   Reply With Quote
Old 08-27-2025, 10:36 PM   #5
Gouki
Drives: 2014 Z/28
Fronts https://ebay.us/m/zQRHIH
Old 08-27-2025, 10:39 PM   #6
Gouki
Drives: 2014 Z/28
Rears https://racingbrake.com/pd1165-21/
Old 08-28-2025, 04:18 AM   #7
docwra
Drives: 2015 Z28
If youre looking for uprated pads Pagid RSC1 are E8091 front and E4906 rear
docwra is offline   Reply With Quote
Old 08-28-2025, 07:29 PM   #8
Gouki
Drives: 2014 Z/28
Docra, you may have a typo.
It's 8091 for the fronts
https://www.paragon-products.com/Pag...091-p/8091.htm
Old 08-29-2025, 05:29 PM   #9
AnythingButTime
Drives: 2015 Z28
That is what I am trying to reverse. Owner #1 2800 miles over 8 or so years. Owner #2 6000 miles over 2 years, didn't want to use up the Carbon Ceramics so he installed the steel conversion. Owner #3 (Me) wants to revert to original. Owner 2 carefully packed the rotors away, but thought he would buy new pads if he needed them in the future not realizing everything would be discontinued. I actually think that is why he sold me the car...he was concerned something would happen to it and parts wouldn't be available.
Old 08-29-2025, 05:31 PM   #10
AnythingButTime
Drives: 2015 Z28
Originally Posted by docwra View Post
If youre looking for uprated pads Pagid RSC1 are E0891 front and E4906 rear
Looking for the Brembo equivalent to stock.
Old 08-29-2025, 05:41 PM   #11
AnythingButTime
Drives: 2015 Z28
Originally Posted by Gouki View Post
I am concerned about eBay, as when you search most of the results are from China...with the few available USA sellers look like they just resell parts...which are probably the same ones from China.
https://www.ebay.com/itm/205646581061
https://www.ebay.com/itm/365479675446
Old 08-29-2025, 07:32 PM   #12
Gouki
Drives: 2014 Z/28
Anythingbuttime - I think you're overthinking this, I've replaced front and rear pads multiple times with both the pagid and OE brembos.
I've also replaced the front rotors at a significantly lower cost using GM CCB rotors reusing the Z28 hats.
I bought these and they were OEM.
https://ebay.us/m/pPteYc
Old 08-29-2025, 08:19 PM   #13
AnythingButTime
Drives: 2015 Z28
You are absolutely correct, I am overthinking this because I don't want to end up with a knock-off pad that adversely affects my rotors. We've weighed the rotors and they retain most of their mass confirming they are the low mileage as stated...seller in my opinion is 100%
I ordered
https://www.ebay.com/itm/335970441842
and
https://www.ebay.com/itm/316783862078
I would be happier (ie. more comfortable) paying double and having them come off the parts truck from GM.
Old 08-29-2025, 09:23 PM   #14
Gouki
Drives: 2014 Z/28
Measure the used pads that thickness against the new ones you've ordered. Unless the owner heavily tracked the car, you might be shocked how close they are to new pads.
Also, you don't really need to stress about the carbon ceramic discs as much. You can get new front rings between $1000-$1300 each, but I doubt you'll need to change them in your entire ownership.
