Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Suspension / Chassis / Brakes
Old 09-21-2025, 09:20 AM   #1
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
Gen 6 Camaro Radius Rods With BMR Spherical Bearings
SOLD!
I used these on my Gen5 '14 SS 1LE and Gen6 '22 SS 1LE.
These are the Gen6 Camaro SS 1LE front (radius rod) diagonal arms (part #s 84051641/42) with the BMR sphericals installed (part # BK070). But I drilled out the BMR spherical spacers to accept the larger Gen5 OE 14mm bolt. The Gen6 arms are shorter than the Gen5 steel arms. This will increase the caster. When used on the Gen5, you will need spacers on each side of the spherical because the Gen6 bushing is narrower than the Gen5. NHV is a little higher with these solid joints. I also made rubber protectors to help keep dirt away from the sherical bearings. Purchasing all the components new is about $500-600 depending on which Gen6 arm you would start off with. These arms also have provisions to add the Gen6 brake cooling deflectors. Here are some threads on the details of using the Gen6 radius rod in a Gen5:
Go to Post #43:
https://www.camaro5.com/forums/showthread.php?t=505806
Go to Post # 141:
https://www.camaro5.com/forums/showthread.php?t=332717
https://www.bmrsuspension.com/?page=...productid=1686
I will also throw in the OE bushings that I pressed out of these arms when I swapped in the BMR bearings.
$300 Shipped to CONUS, PayPal only. If interested PM me here on the forums.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather
cdb95z28 is offline   Reply With Quote
Old 03-11-2026, 10:16 AM   #2
cdb95z28
cdb95z28's Avatar
SOLD! THANKS MAT!
