Old 12-05-2025, 09:07 AM   #1
KGBM
Drives: 2014 Chev Camaro SS
2010-2015 Camaro Rear upper knuckle bushings
As many of you know. Gen 5 Camaro 2010-2015 have an issue with rear suspension upper knuckle bushings.
There is no replacement part and the knuckle has been discontinued.
Some have tried installing a standard bushing in place of the MonoBall bushing but it does not last.
I found a solution that works perfectly.
I sourced out a Monoball bushing that when machined to match the original one is the solution.
Let me know if anyone needs help with this fix.
KGBM is offline   Reply With Quote
Old 12-30-2025, 05:31 PM   #2
That Limey Dude
Drives: 2010 Camaro
I've had exactly the same problem with mine.
After chasing around the Internet, with nobody supplying them, with much head scratching and gnashing of teeth on my part, I believe that I've found an answer.
I came across a company in Austin Tx, called SPL Suspension.
They are making the same joint for gen 6 Cams, but not 5th gen at present. I've been in touch with them, and the are hoping to supply them for 5th Cams in the next few months.
They are an upgrade on the stock ac delco ones, so expect to pay more for them.
I'm looking forward for them to start production!!!
Regards TD ��
That Limey Dude is offline   Reply With Quote
Old 12-30-2025, 06:52 PM   #3
redcoats1976
Izzat the clunk i get when backing out of my garage?
Old 01-01-2026, 07:30 PM   #4
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
This guy seems to have found a solution.
https://www.camaro5.com/forums/showthread.php?t=635747
camaro bushing
