Old 12-21-2025, 06:43 PM   #1
xstuntman
Drives: 2012 Victory Red LFX
New remote cover?
Plenty of old threads on this but i thought i would maybe get an update on the subject.
I finally had an afternoon cruise around town after a 4 month hiatus and a pleasant 65 degrees in the panty dropper.
However....
I noticed my remote buttons are looking worse for wear after almost 14 years and 16k miles. The remote works fine btw, just the buttons looking kinda melted/distorted.
Anybody recommend a good replacement I can drop the guts into? Or just step up and get a whole new unit instead of futzing around as it is fairly old at this point?
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
xstuntman is offline   Reply With Quote
Old 12-21-2025, 07:10 PM   #2
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
I bought these a few years ago. Swapped the board & no issues.
https://www.amazon.com/dp/B09LVB9Y9B?
ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_15
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 12-21-2025, 07:14 PM   #3
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
My best suggestion is go to the dealer and have them order a new set for you. Don't trust the Amazon/Ebay remote crap as it does not live up to what they say it does. I purchased new key fobs from the dealer new and of course paid $$ for it. Then at that time frame I purchased new covers for them at the parts counter. Pics below...
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 12-21-2025, 07:16 PM   #4
SummitWhite11
Drives: 2010 2LT/RS
I purchased those exact ones off of Amazon years ago and they were crap! Couldn't get them to work. Money wasted.
2010 2LT/RS
Old 12-23-2025, 11:00 AM   #5
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
I bought two of these a few years ago when my fobs wore out. A much needed upgrade.
https://www.ebay.com/itm/167779515686
Old 12-23-2025, 11:14 AM   #6
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
You can't beat the original factory internals, so if yours still work, I would do something like this.
https://www.ebay.com/itm/20253473994...BlBMUKTX-MLpZg
If you want a new remote, I bought these. One is for the reconditioned fob and the other is to get the key cut. You just send them a pic of yours. Not exactly cheap but appears to be OEM stuff. Not sure how they refurbish them. My guess is they replace the button covers and put new bowties on the back. Aftermarket fobs don't have the recess for the bowtie. These do.
https://www.ebay.com/itm/112320295919
https://www.ebay.com/itm/11367722776...8AAOSwIt1i8pc4
Old 12-23-2025, 11:41 AM   #7
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
No way I would spend that on a reconditioned fob. You can get two new shells and spend 10 minutes changing everything over for less. If you must have a new one, my dealer wanted $60 for a new fob, cut and programmed. $50 for a reconditioned fob, cut, that isn't even guaranteed to work is a hard pass.
Old 12-23-2025, 12:45 PM   #8
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
I did this one as well except I found it on Amazon, not ebay.
Old 12-23-2025, 12:49 PM   #9
xstuntman
EBay order is in!
Thanks guys.
Old 12-30-2025, 04:57 PM   #10
CamaroCracka
It worked. If it had not, I would have returned it. I doubt my dealer is doing $60 for a new fob cut. They've been wanting to do a recall on my keys for years so can't see how they are going to cut me a switchblade fob.
Last time I got a spare key made for the convertible, the locksmith charged $40 just to cut it and the dealer wanted more, although I don't recall how much more. I got that fob off Amazon for $20 and it lasted about two years, never working as good as the factory unit. When it failed, I transferred the original internals to that fob, and it works like a charm to this day.
The refurbed fob I got off eBay, which the seller is a locksmith in NC, was a third fob I wanted to have around to make sure I have switchblade keys well into the future, so no internals to transfer on that one. If you have the internals in working order, a new cover works well too, but I prefer fobs that look like the originals and that is a bit harder to find.
Old 01-07-2026, 11:30 AM   #11
scott71law
scott71law's Avatar
Drives: 2011 LS auto
Hey you guys talk about transferring internals of these things, what goes into that process? I'm worried I will try that and wreck my only working fob lol. If it is pretty simple to do I'd like to try it as I have a new amazon fob to use, and mine is pretty jacked up with distorted buttons, etc.
Thanks for any info, Scott
scott71law is offline   Reply With Quote
Old 01-07-2026, 01:02 PM   #12
xstuntman
The one I bought can be programmed fairly easy it looks like but just swapping over the guts was simple and you then don't have the new blank key cut. I watched several vids on the 'tube first tho.
The factory fob is glued shut and the majority of the half hour doing the job was getting it apart. Cut seams, pry, cut seams, pry again, etc.
30 minutes total and it tested out fine. I think I only cussed once during the event and no band aids needed.
Old 02-06-2026, 06:47 PM   #13
scott71law
scott71law's Avatar
I bit the bullet and ordered a new GM fob from a local locksmith who is going to cut and program it for $135 out the door. Also has a “guarantee” that is will work, I’m guessing that’s just a promise to replace it if it doesn’t, but we’ll see.
My current fob does not have the GM logo on it, the locksmith told me the OEM fobs all have the logo. Go figure. At least I’ll have a backup now and will primary use the GM unit.
Old 02-06-2026, 09:06 PM   #14
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
The "logo" is actually just a sticker. Mine came off years ago. Never bothered to order more.
