Old 12-29-2025, 07:36 PM   #1
KEN CROCIE
Drives: CAMARO 2SS 2015 convert.
fuse pull
Awhile back I remember a discussion about pulling a fuse for octane matching.
Could someone refresh my memory please?
KEN CROCIE is offline   Reply With Quote
Old 12-30-2025, 08:59 AM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Here ya go... #5 and #20.. Leave them out for about 30 minutes or so, reinstall, make sure you have GOOD fuel in the tank, at least 91 or higher..
https://www.camaro5.com/forums/showthread.php?t=38964
Old 12-30-2025, 11:38 AM   #3
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
^^^^ This sticky will give you everything you need to know.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
