Old 01-06-2026, 07:29 PM   #1
Black 13 Maro
Drives: 13' Black 2SS/RS
6l80E Transmission fluid and filter service
Dropping the pan and changing filter this weekend, car has 70k on it and it’ll be the first service. I know, should have done it sooner.
I have 8 quarts of Merc 6 synthetic valvoline synthetic on the shelf. How many quarts do you guys typically put back in for a pan drop service? On my Duramax I have to get the fluid up to *170 and open the fluid level plug till it trickles out.
Just asking to see if there’s a hard number for how many quarts go back in or if there’s a specific way of going about it. I tried to search here and YouTube but nothing concrete and most procedures I found were being done on trucks.
Thank you 🙏
Black 13 Maro is offline   Reply With Quote
Old 01-06-2026, 08:42 PM   #2
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
you can buy the jennetty trans dip stick, then you won't have to guess.
The 6L80 transmission has a total dry capacity of about 11-12 quarts, but a standard pan drop and filter change requires around 6-7 quarts, while a full overhaul can take up to 10-12 quarts
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 01-07-2026, 04:21 PM   #3
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
V8 will be 8 quarts. Your dipstick will show that
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 01-08-2026, 07:24 PM   #4
Black 13 Maro
Thank you, will order the dipstick tonight.
Old 01-08-2026, 07:25 PM   #5
Black 13 Maro
Thank you sir
Old 01-24-2026, 01:48 AM   #6
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
Not sure why no one's mentioning it, but if you still have the OEM trans pan, there's just a leveling plug (which people mistaken as a drain plug). You can technically "drain" through that plug, but it won't get all the fluid out, of course.
I ended up swapping many aftermarket pans, and those come with both the leveling and main drain plugs. And yes, it would be nice to get the dipstick, as you don't have to guess/estimate the fluid level, and you can also physically check the quality/condition of the trans fluid.
TheBrightSide is offline   Reply With Quote
Old 01-24-2026, 08:57 AM   #7
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
I'm no master mechanic but I believe that would be the crankcase, not tranny!
Moto-Mojo is offline   Reply With Quote
Old 01-24-2026, 04:55 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Agreed...
Old 01-24-2026, 10:39 PM   #9
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Total Capacity: ~11–12.5 quarts.
Pan Drop/Filter Change: ~6–7 quarts.
Old 01-28-2026, 12:24 PM   #10
Wizard1183
Wizard1183's Avatar
Agreed...
A 6l80 dry is 12.4 quarts is it not? It’s about 8 that comes out no?
Old 01-29-2026, 07:35 PM   #11
Wizard1183
Wizard1183's Avatar
Thank you for clarification. I know it was close.
