Old 02-03-2010, 01:37 PM   #1
stangspanker
stangspanker's Avatar
Drives: Camaro
Flywheel Torque Specs?
Does anyone know what the Torque specs on the flywheel to crank are? and also what the tq specs are on the bellhousing. I know they are the same as stock but what is stock?
stangspanker is offline   Reply With Quote
Old 02-03-2010, 03:07 PM   #2
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
Auxiliary Transmission Oil Cooler Quick Connect Fittings
25 N·m
18 lb ft
Auxiliary Transmission Oil Cooler Brace to Skid Bar Bolt
25 N·m
18 lb ft
Auxiliary Transmission Oil Cooler Bracket to Body Nuts
8 N·m
71 lb in
Auxiliary Transmission Oil Cooler to Bracket Mounting Bolts
22 N·m
16 lb ft
Case Extension to Case Assembly
16
6
M10x1.5x40
55 N·m
41 lb ft
Control Solenoid Valve Assembly and Control Valve Lower Body Assembly to Control Valve Upper Body Assembly
310
6
M5x0.8x55
8 N·m
71 lb in
309
10
M5x0.8x45
8 N·m
71 lb in
Control Solenoid Valve Heat Sink to Valve Body
312
2
M5x0.8x53
8 N·m
71 lb in
Control Valve Upper Body Assembly to Control Valve Lower Body Assembly
301
12
M5x0.8x36
8 N·m
71 lb in
Control (with Body and Valve) Valve Assembly to Case Assembly
22
6
M5x0.8x73
8 N·m
71 lb in
Fluid Pan Assembly to Case Assembly (6L80)
30
18
M6x1.0x20
9 N·m
80 lb in
Fluid Pan Assembly to Case Assembly (6L50)
30
17
M6x1.0x20
9 N·m
80 lb in
Fluid Pump Cover Assembly to Torque Converter Housing
231
13
M6 1.0x40
11 N·m
97 lb in
Input and Output Speed Sensor Assembly to Control Valve Upper Body Assembly
302
2
M6x1.0x20
12 N·m
106 lb in
Line Pressure Test Hole Plug to Torque Converter Housing
202
1
1/8-27 NPTF
11 N·m
97 lb in
Manual Shaft Detent Assembly to Valve Body
23
1
M6x1.0x14.5
12 N·m
106 lb in
Prop Shaft Trans Flange to Output Shaft
39
1
M22x1.5x14
105 N·m
77 lb ft
Shift Control Assembly to Body Nuts
4
9 N·m
80 lb in
Shift Control Knob Screw
1
2 N·m
18 lb in
Shift Control Linkage to Manual Shift Shaft Nut (AWD)
1
20 N·m
15 lb ft
Shift Control Linkage to Manual Shift Shaft Nut (RWD)
1
15 N·m
11 lb ft
Shift Control Linkage to Shift Control Assembly Nut
1
9 N·m
80 lb in
Torque Converter Housing Assembly to Case Assembly (6L50)
3
8
M8x1.25x50
31 N·m
23 lb ft
Torque Converter Housing Assembly to Case Assembly (6L80)
3
9
M10x1.5x50
72 N·m
53 lb ft
Torque Converter to Flywheel Bolts
3
63 N·m
46 lb ft
Trans Oil Level Check Plug to Fluid Pan Assembly
31
1
M12x1.75
25 N·m
18 lb ft
Transmission Oil Cooler Pipe Clip to Oil Pan Nuts
10 N·m
89 lb in
Transmission Oil Cooler Pipe Clip to Torque Tube Bolts
12 N·m
106 lb in
Transmission Oil Cooler Pipes to Transmission Bolt
16 N·m
12 lb ft
Transmission to Engine Block Bolts
10
50 N·m
37 lb ft
Transmission Support Assembly to Body Bolts
4
60 N·m
44 lb ft
Transmission Support Assembly to Transmission Bolts - RWD
2
60 N·m
44 lb ft
Transmission Support Assembly to Transmission Bolts - AWD
2
110 N·m
81 lb ft
*Reference number refers to the component callout number in Disassembled Views
WICKEDSS is offline   Reply With Quote
Old 02-03-2010, 03:11 PM   #3
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
Clutch Housing Assembly to Transmission Case Bolts
48 N·m
36 lb ft
Clutch Housing Pump Plug
27 N·m
20 lb ft
Concentric Slave Cylinder Bolt
12 N·m
106 lb in
Coolant Temperature Sensor
39 N·m
29 lb ft
Cooler Line Return Fitting
18 N·m
13 lb ft
Cover Plate Bolts
20 N·m
15 lb ft
Extension Housing Plug
27 N·m
20 lb ft
Extension Housing to Transmission Case Bolts
48 N·m
36 lb ft
Gear Select/Skip Shift Solenoid
40 N·m
30 lb ft
Neutral Return Cam Spring Retaining Bolt
25 N·m
18 lb ft
Propshaft Transmission Yoke Nut
136 N·m
100 lb ft
Pump Outlet Cooler Fitting
17 N·m
13 lb ft
Reverse Idler Shaft Bracket Bolts
25 N·m
18 lb ft
Reverse Lockout Assembly Bolt
18 N·m
13 lb ft
Reverse Lockout Solenoid
40 N·m
30 lb ft
Shift Control Adapter Plate Bolt
18 N·m
13 lb ft
Shift Control Adapter Plate Nut
12 N·m
106 lb in
Shift Detent Assembly
40 N·m
30 lb ft
Shift Guide Plate Bolts
22 N·m
16 lb ft
Shift Lever Guide Bolts
27 N·m
20 lb ft
Shift Shaft Detent Plug
24 N·m
18 lb ft
Transmission Bolt
48 N·m
35 lb ft
Transmission Case Drain Plug
27 N·m
20 lb ft
Transmission Case Fill Plug
27 N·m
20 lb ft
Transmission Fluid Pump Outlet Pipe Fitting
18 N·m
13 lb ft
Transmission Fluid Temperature Sensor/Drain Plug
18 N·m
13 lb ft
Transmission Mount to Transmission Case Bolts
60 N·m
44 lb ft
Vehicle Speed Sensor (VSS) Bolt
11 N·m
96 lb in
Old 02-03-2010, 03:27 PM   #4
1 BAD RS 2 SS
1 BAD RS 2 SS's Avatar
Drives: 2010 RS 2 SS
info. overload
1 BAD RS 2 SS is offline   Reply With Quote
Old 02-03-2010, 03:34 PM   #5
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
HaHa like you.....I didnt want to read through them all.....Its in there somewhere
Old 02-03-2010, 03:36 PM   #6
stangspanker
Drives: Camaro
10
50 N·m
37 lb ft
Im assuming this is for the bellhousing
Did I miss the Flywheel torq spec? For an LS3
Thanks by the way!!!
Old 02-03-2010, 03:40 PM   #7
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
Install the remaining NEW engine flywheel bolts.
• Tighten the NEW engine flywheel bolts to 30 N·m (22 lb ft).
• Tighten the NEW engine flywheel bolts an additional 45 degrees using the J 45059 meter
And yes that is correct.......Install the transmission mounting bolts and tighten to 50 N·m (37 lb ft).
Old 02-03-2010, 03:46 PM   #8
DarricSS
DarricSS's Avatar
Drives: '10 Camaro SS
Holly crap! Nice info...thanks Wicked!
2010, SIM, 2SS/RS, LS3, CGM Stripes
DarricSS is offline   Reply With Quote
Old 02-03-2010, 03:55 PM   #9
stangspanker
Drives: Camaro
22 foot pounds..? um... so hand tight? LOL .Thats it? WOW
Old 02-03-2010, 04:00 PM   #10
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
No problem working at a dealership i can look up any spec's on these car's......Down side is it doesnt let me post pictures for Schematic and Routing Diagrams...
Old 02-03-2010, 04:01 PM   #11
DarricSS
DarricSS's Avatar
22 ft. lbs is actually quite a bit of torque considering the size of the bolts and the amount of stretch they can take...if it was Inch pounds I would be worried...
Old 02-03-2010, 04:01 PM   #12
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
Its 22 and then Tighten the NEW engine flywheel bolts an additional 45 degrees using the J 45059 meter.................GM does LBS and DEGREES
Old 02-03-2010, 04:04 PM   #13
stangspanker
Drives: Camaro
So torque to 22 foot pounds and then tighten an additional 45 degrees?
J 45059 meter? Can I buy this at any auto parts store?
Old 02-03-2010, 04:08 PM   #14
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
Im not sure where you can get one we order out stuff through our parts
Torque Converters CamaroSpike23 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 48 08-16-2014 02:07 AM
Stereo GUIDE ALL READ WildBeast15 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 29 09-11-2010 01:14 AM
Brembo brake caliper torque specs sting808 Suspension / Brakes / Chassis 6 02-03-2010 12:16 PM
Torque Converters Explained tbyrne V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 01-07-2010 12:38 PM
ProTorque Converters - FREE Shipping! tbyrne Transmission / Driveline 0 01-07-2010 12:36 PM
