Old 02-06-2010, 12:54 AM   #1
caverman
caverman's Avatar
Drives: '69 SS Convertible
Recommended Skip Shift elimenator?
Can anyone recommend a decent yet relatively in-expensive Skip Shift elemenator?
$30 for an SLP seems a little high when the DYI articles are saying you can do it with just a little resistor. Not sure if I want to buy a pre-made one or go with the DYI article. Eventually I'll have it taken out when I tune the car but that might be a little bit.
Build Journal
Old 02-06-2010, 01:08 AM   #2
BLK2SS
BLK2SS's Avatar
Drives: Black 2SS
You can get them on ebay cheaper. Here is an example.
http://cgi.ebay.com/ebaymotors/2010-...item53df6dcc77
BLK2SS is offline   Reply With Quote
Old 02-06-2010, 02:06 AM   #3
Ivan @ Southwest Speed
Does anybody know if the T-56/Fourth Gen DIY will indeed work or not for the new Tranny?? Has anyone successfully tried it??
That info would be good to know.
-Ivan
Old 02-06-2010, 02:17 AM   #4
BLK2SS
BLK2SS's Avatar
Drives: Black 2SS
-Ivan
It will work. The same skip shift eliminator is used on all of the models.
Old 02-06-2010, 09:15 AM   #5
Russell James
Russell James's Avatar
I think I've bought about 10 little resistors from Radio Shack over the years. The same 2.2K ohm .5 watt resistor has worked perfectly in all my Vette C5's, 4th gen F-body's, GTO, C6... and on my way home from picking up my '10 Camaro from the dealer, first stop was Radio Shack for another .99 mod. At 15 miles on day 1 of ownership, my skip shift was history in my Camaro. Never even felt it activate once.
My brain won't let me spend $30 when .99 does the exact same thing. And .99 is even highway robbery. Radio Shack use to have 5 packs for .99, then the capitolist bastards packaged them individually - for the same price. They must have sensed skip shift market demand.
Old 02-06-2010, 09:42 AM   #6
csjrishere
Drives: 2010 Camaro SS
This is the one I am using. It works great!!!!
csjrishere is offline   Reply With Quote
Old 02-06-2010, 09:55 AM   #7
Apex Paul
Apex Paul's Avatar
Drives: Wagon Queen Family Truckster
PM me your shipping info and I will send you one.
Apex Paul is offline   Reply With Quote
Old 02-06-2010, 10:36 AM   #8
J-Rod6410
M6 9 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
Just ordered mine. Can't beat 12 bucks for a premade sealed connector
TEAM LS3 Best pass: 9.61 @ 146 with M6
TBDRWHP TBDRWTQ ECS S/C 408, YSi, m6, Mantic Triple, ZL1 diff
#BuiltByJRod.... J-Rod's Speed Shop.... Tuned by: Matt Sorian @ MS Tuning
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 02-06-2010, 10:58 AM   #9
caverman
caverman's Avatar
In case I want to give this a try are you sticking in the the resistor, bending it sideways, and then taping it up with electrical tape or something? Aren't you concerned about water getting splashed up there and/or the tape eventually coming off?
I kinda like the looks of the one that was on ebay because it looks like it would seal up the orignal connections.
Build Journal
Old 02-06-2010, 10:59 AM   #10
caverman
caverman's Avatar
Do you have any pics of yours? How much do you sell them for?
Build Journal
Old 02-06-2010, 07:39 PM   #11
Apex Paul
Apex Paul's Avatar
Caverman, I don't have an actual pic on my home computer, but it is made from Delphi weatherpack connectors, using the rubber seals around the wiring as well as inside the plug that fits into the transmission when you disconnect the Camaro's harness. Off the top of my head, we retail those for $27 or $29 dollars, somewhere in that ball park.
A quick web search and I came up with this pic that shows the Delphi connectors. This one would also fit the Camaro. The difference being that one way is using two parts and you zip tie the harness, the other is "spliced" in line with the original harness.
Old 02-06-2010, 09:05 PM   #12
FRKNlo
FRKNlo's Avatar
Drives: VStar 1100 Classic, 2010 CGM 2SS/RS
Using the adaptive performance skip shift eliminator. Cheap and it works.
FRKNlo is offline   Reply With Quote
Old 02-07-2010, 12:43 AM   #13
wbt
Drives: 2010 Challenger R/T;2011 Mustang GT
Very nice! Just ordered one myself.
wbt is offline   Reply With Quote
Old 02-07-2010, 12:55 AM   #14
caverman
caverman's Avatar
Using this Adaptive Performance one....do you just un-plug the original plug and plug one side of the eliminator in at the transmission and then plug what came off the trans to the other end of the eliminator?
Just making sure that's how they get installed.
Build Journal
Camaro Skip Shift Eliminator.... southerncarparts V8 Bolt-Ons & Tunes 22 10-04-2019 11:18 AM
M6 Owners and Skip Shift Beware! DkknightX 5th Gen Camaro SS LS LT General Discussions 173 01-26-2010 05:14 PM
Skip shift function, or malfunction? AMERICANMADE 5th Gen Camaro SS LS LT General Discussions 53 09-18-2009 09:38 PM
SLP Skip Shift Eliminators Available @ MarylandSpeed! MarylandSpeed V8 Bolt-Ons & Tunes 0 09-18-2009 02:50 AM
Avoid skip shift in the break-in? Vash Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 7 05-27-2009 11:39 AM
