Old 02-11-2010, 05:36 PM   #1
MTI Racing Kevin
MTI Racing Kevin's Avatar
Drives: 2010 Camaro
MTI Racing Dyno Pull
Check out the dyno results for our stage 1 camshaft and American Racing Header system installed in a customers 2010 Camaro with the automatic transmission. At MTI Racing, we refer to this as the "Un-Cam" because it drives almost exactly like stock. This camshaft is designed specifically to take advantage of the awesome airflow potential of the LS3 cylinder head. Subsequent testing has revealed that it is also an excellent choice for L99 equipped automatic transmission Camaros. This camshaft can also be installed in an manuel car for even more HP and Torque.
We also installed the MTI Racing Sport Lowering Springs along with our Swaybars for 2010 Camaro. Not only does this Camaro scream down the quarter mile but it also takes the turns with authority.
I also want to thank Michael for bringing his Camaro over and letting us thrash on it a bit. He was very happy with the results. Hey Michael let me know when you are ready for that supercharger.
MTI Racing Kevin is offline   Reply With Quote
Old 03-26-2010, 06:23 PM   #2
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
you made that much of a difference with just headers and a cam? i cant believe no one has commented in this thread
trudawg660 is offline   Reply With Quote
Old 03-26-2010, 06:55 PM   #3
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
I don't know about L99s (power with cams), but I made 95 rwhp with headers, intake, cam, and a tune on my LS2 GTO.
And I'm very interested in that MTI cam. I like the idea of a mild/sleeper type cam that makes good hp.
Old 03-26-2010, 07:05 PM   #4
trudawg660
i want a cam, i love the exhaust sound and the hp gains. but i want one that doesn't make the drivability worst, even worst gas milage or a horrible drone at cruising speeds
Old 03-28-2010, 09:58 PM   #5
trudawg660
i can't believe this thread keep going unseen.
Old 03-28-2010, 10:05 PM   #6
Supercharged SS
Drives: 2010 Camaro
MTI, Is this a VVT cam or did you swap the L99 into an LS3? I'd like to add a cam to get more power without adding boost. Is this just like a regular cam swap or do you need to pull the motor? Thanks for your help.
Old 03-28-2010, 10:16 PM   #7
trudawg660
from the description they make it seem like there not making it into the ls3
Old 04-01-2010, 05:19 PM   #8
MTI Racing Kevin
Drives: 2010 Camaro
Stage 1 Cam
The Stage 1 Cam was designed to be used with the stock torque converter in the L99 based Camaro, and as you can see it makes terrific power in that application. However, this cam can be used and makes awesome power in the LS3 based engine as well. This camshaft, although it is our stage 1 works fantastic with headers and our CIA as demonstrated above. If you are thinking of supercharging your Camaro this cam works perfectly with the Magnuson TVS2300 supercharger system as well as any other supercharger or turbo to make excellent power and keep the everyday drivability intact. Let me know if you have any questions.
Bilstein Coilovers with MTI Racing MTI Racing Wheels and Tires Talk Sponsored by The Tire Rack 20 01-18-2013 01:15 PM
MTI Racing Stage 1 Suspension Upgrade MTI Racing Suspension / Brakes / Chassis 0 01-27-2010 11:14 AM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
MTI Racing Camaro 182 mph at Teas Mile MTI Racing Dragstrip and Launch Techniques Discussion 8 10-26-2009 10:46 AM
New Edition to MTI Racing "Six Shooter Shifter" MTI Racing Interior Parts & Accessories 0 09-17-2009 02:33 PM
