Old 02-13-2010, 02:30 PM   #1
Lava
LSU Tigers!!
Drives: 2010 Camaro SS
Window Allignment Issues
Ok, a few weeks ago I get into my car and the driver side window actuator does not self adjust down or up when the door is opened then closed. I look at the digital info display and it has a message to roll the window down all the way then roll it up again. Then it says to do the same process with the passenger side window. After doing that It self adjusts again and no problem till yesterday. I get the same response on the display and the widow does not work properly. Well, I do the directions it gives and no luck, FAIL. Window will not self adjust or auto roll up and message will not go away. After attempting it several times with no luck I give up and stop by the dealer to ask a Tech for help. He does some research with GM online and fids a reported issue about this with other Camaro's. The Info says to push both window controls down till the windows are all the way down and continue to hold the buttons for three seconds, then immediately pull the buttons up and hold them in the up position for three seconds. This will allow the window memory to readjust and reset itself. The tech told me that it says a fix is on the way because it is a reported software issue and for me to check back at a later time because more than likely no info will be sent from GM making customers aware of the issue or a fix when it is done. Just thought I would post in case others have had a similar instance.
Lava is offline   Reply With Quote
Old 02-13-2010, 07:04 PM   #2
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Disconnect the battery for 10 min and reconnect and try again.
HeavyD is offline   Reply With Quote
Old 02-13-2010, 09:13 PM   #3
Lava
LSU Tigers!!
Thanks, but you don't have to go through all that. Just do what the dealer said and it should self adjust that way. No need to take the trunk apart and disconnect the battery because you will have to do the window alignment anyway when it looses memory.
Old 02-13-2010, 10:34 PM   #4
BIG_V_SS
BIG_V_SS's Avatar
Drives: 2010 Chevrolet Camaro 1SS/RS
I just installed my footwell lights today so I disconnected the battery. When I hooked the battery back up my window was stuck in the down position. I ended up doing something of a variation of what you said and finally it started working. I made a couple of calls to the dealer who was clueless on what to do. I wish I had read this before today. Good information!!
"Sailors belong on ships, ships belong at sea. Land is a mere navigational hazard to be fired upon when necessary!!"
BIG_V_SS is offline   Reply With Quote
Old 02-14-2010, 03:03 PM   #5
MikeZ28
Drives: '04 GTO, '00 Z28, '95 Z28
I don't care about a little wind noise, the 4th gens were fine with their window configuration... this window indexing has gotta be more trouble than it's worth. An answer to a question no one asked.
MikeZ28 is offline   Reply With Quote
Old 03-20-2010, 08:28 PM   #6
OctaneSS
OctaneSS's Avatar
I have been having this issue also and have reprogrammed the indexing several times. Now my window sometimes won't even work and then a couple hours later it will work. and then it will prompt me to reprogam the window indexing. Should I disconnect the battery to see if that will help with the windows not working from time to time?
OctaneSS is offline   Reply With Quote
Old 03-20-2010, 08:54 PM   #7
tjmac49
Drives: 2010 Camaro SS/RS, IBM, L99
Oh, Boy; something to look forward to!!
tjmac49 is offline   Reply With Quote
Old 03-20-2010, 11:05 PM   #8
thiggin2
thiggin2's Avatar
Drives: 05/07 Chevy's
Well there is now a revised PI (3/19/10) on this indexing issue. There are new regulator/motor assemblies that will need to be installed. Just talk to your dealer and mention "PIC5264B".
thiggin2 is offline   Reply With Quote
Old 03-21-2010, 08:24 AM   #9
OctaneSS
OctaneSS's Avatar
awesome, hopefully it fixes the issue. thanks!
Old 03-21-2010, 06:48 PM   #10
Jferrell88
Jferrell88's Avatar
Drives: black 2ss/rs
just had trouble with mine today. i did what the message said and the message was still displayed on the screen. then i did it again when i got home and now its fine so i dont know guess ill check with the dealer.
Jferrell88 is offline   Reply With Quote
Old 05-13-2010, 07:50 AM   #11
jlpearl
Performance-Dyno.com
jlpearl's Avatar
Drives: 2013 Camaro ZL1
I jsut had PIC5264B done and my window is finally working correctly. Well it has been for the last two days. They had to change the weather stripping out too.
jlpearl is offline   Reply With Quote
2010 Camaro Rear Window Lower Window Seal Improperly Installed at Delivery/Fix Alan C. Higgs Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 14 03-11-2011 03:35 PM
Auto Indexing Window Broken Gen5SSRS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 19 01-21-2010 07:29 AM
Does R6P Show up on Window Sticker? bub 5th Gen Camaro SS LS LT General Discussions 23 08-23-2009 11:02 PM
R6P-If Window Stckr shows price increases-How do u get dealer 2 honor org MSRP price? renderinfo Camaro Price | Ordering | Tracking | Dealers Discussions 48 06-03-2009 11:03 AM
