Old 02-16-2010, 07:53 AM   #1
ELDuran
ELDuran's Avatar
Drives: 2010 2LT RS Camaro (Rally Yellow)
Question Stupid question but...
At the risk of sounding stupid I have to ask, how do I get my Ipod to work? I basically plugged my Ipod into the USB port in the Camaro, so now how do I get sound?
Back-2-Back Champs L.A. Lakers!
ELDuran is offline   Reply With Quote
Old 02-16-2010, 09:02 AM   #2
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
not a stupid question. When your iPod is selected as the source, it should start playing with the first song. Or you can select playlist (if you have one on the ipod) and hit play. Can you see that it selected a song to play and you just don't have sound? Or is it that it's not selecting the device, nor playing any music?
Old 02-16-2010, 09:59 AM   #3
ELDuran
ELDuran's Avatar
Well I plugged it in and nothing happens. My radio continues playing or my CD. I tried pessing the Aux button but that didn't do it either. The ipod shows its playing a song but there's no audio. I think I may have one of those classic 30gbs ipods, if it makes a difference. What could be the problem? Thanks in advanced.
Old 02-16-2010, 10:09 AM   #4
Sevn86
Sevn86's Avatar
unplug it and plug it back in and see if it picks it up cuz mine sometimes wont and so thats what i do...just make sure your radio is on...
3100 Sequenced:10/12/09
3400 Broadcast:10/22/09
3800 Produced:10/27/09
4200 Shipped:10/29/09
Old 02-16-2010, 10:54 AM   #5
tjmac49
Drives: 2010 Camaro SS/RS, IBM, L99
+1.
tjmac49 is offline   Reply With Quote
Old 02-16-2010, 11:17 AM   #6
ELDuran
ELDuran's Avatar
I will try this as soon as I get off work. Hopefully this fixes the problem. Thanks!
Old 02-16-2010, 11:39 AM   #7
deljaso
deljaso's Avatar
Drives: 2010 1LT/RS
If that doesn't work, I'd try a different cable.
Then if it still doesn't work, I'd try to borrow someone's ipod and plug it in to the usb port to see if it shows up.
My car switches to the ipod automatically when I plug the ipod in (or when I turn the car on) -- if it's already been plugged in, you are using the correct button to switch to the ipod (aux button).
deljaso is offline   Reply With Quote
Old 02-16-2010, 12:29 PM   #8
Lydon
Lydon's Avatar
Drives: 2010 2SS Camaro
Once your iPod is plugged in, you can control it like you would if you were listening to it normally. Once you have done this the initial time, without unplugging it again, it will play through the radio anytime you select it thru the Aux button. It should also pick up where it left off each time you select it. I am using an older Nano it works fine, so you Classic should work as well. Let us know the outcome.
Karen
Lydon is offline   Reply With Quote
Old 02-16-2010, 12:45 PM   #9
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Great troubleshooting tips!!
And like deljaso said, when your car is one and you plug the ipod in, it should default to the iPod/Aux on the radio display, and start playing.
Old 02-16-2010, 12:57 PM   #10
CaliEMT
Decepticons. . . MOBILIZE
CaliEMT's Avatar
Drives: 2010 2SS/RS Black
Not the Aux Button. You have to push the Source button. Is it PDIM or do you guys just have the AUX input jack? I have the PDIM
CaliEMT is offline   Reply With Quote
Old 02-16-2010, 01:25 PM   #11
Snakestang65
Drives: 2013 Blue Ray ZL1
Last but not least, disconnect the battery (you will need a 10mm socket to remove the negative battery cable), then wait about 10 minutes (I actually waited about an hour), then reconnect the battery.
When you get back in after connecting the battery, you will have to reset all your preferences, and re-teach the indexing for the windows (follow the directions on the display).
Try your IPOD again at this point (via the source button). This worked for me...
Snakestang65 is offline   Reply With Quote
Old 02-16-2010, 05:20 PM   #12
ELDuran
ELDuran's Avatar
Well I tried this and it didn't work either. I made sure the radio was on, I plugged it in but the radio continued playing. It didn't recognized my ipod. So I left it plugged in and I shut off the engine and opened my door. I turned the engine back on and still nothing. While the engine was running I unplugged the Ipod from the USB port and then I plugged it back in and the radio still played, not recognizing my ipod. But my Ipod showed it was playing a song.
I guess it ain't compatible with my Ipod. :(
Old 02-17-2010, 02:20 PM   #13
SSInfernoSS
Drives: 2010 Camaro 2SS
Have you been using a phone ? There is a button that makes the audio muted. Do you have another dock in your home that the ipod can be tested there? Anyone else have an iPOD that you can test with your car, as stated above? Just start to elimate the problems one, by one, until you find the solution.
Check Mute
Test different cable
Test iPOD on dock (In home or whatnot)
Test someone else's iPOD
SSInfernoSS is offline   Reply With Quote
Stupid question Revo1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 11-09-2009 02:15 PM
Stupid question yay should i get ls3 if i dont know how to drive manual yet thejoker1232 5th Gen Camaro SS LS LT General Discussions 29 10-22-2009 02:39 PM
Stupid question re PDIM v6sonoma 5th Gen Camaro SS LS LT General Discussions 10 10-14-2009 12:36 PM
may be a stupid question but... honeybucket99 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 1 10-01-2009 11:58 AM
IRS question 454lsxss Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-30-2008 10:06 PM
