Old 02-19-2010, 01:17 PM   #1
75rusty
awesome!
Drives: 07 Jetta WB, '92 GTI 16vT, '76 LUV
M6 V6/V8 rear end, whats the difference?
I was under the impression that all the limited slip rear ends were the same, aside from gears. Am I wrong?
75rusty is offline   Reply With Quote
Old 02-19-2010, 02:22 PM   #2
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
Nope, all the same except the V6 auto.
Robert91RS is offline   Reply With Quote
Old 02-19-2010, 09:02 PM   #3
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
v8 and v6 rear diff's are different, the v8 has a larger ring and pinion, larger posi unit, and has more axle splines than the v6 unit, housing is different also
Old 02-19-2010, 09:06 PM   #4
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
As far a I know the manuals are the same... just the auto V6 is different.
Sterling is offline   Reply With Quote
Old 02-19-2010, 09:12 PM   #5
Agent Atomic Orange
Agent Atomic Orange's Avatar
Drives: 2010 Camaro LS IOM M6
6 and 8 Manuals share the same rearend
Airaid CAI (V2 Tube)/ Flowmaster American Thunder/ Barton Shifter Kit/ Hotchkis Sport Sway Bars/ Hotchkis Sport Springs/ AAC Lights/ GM Trim Kit/ Tint/ Pioneer Premier Champion Series Sub/ Pioneer 1500 Watt Amp
Agent Atomic Orange is offline   Reply With Quote
Old 02-19-2010, 09:19 PM   #6
camaro1
camaro1's Avatar
v6 cars have a 195mm ring gear, v8 cars have a 218mm ring gear
Old 02-20-2010, 09:29 AM   #7
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
Your sizes are correct but according to the catalog the only car to use the 195mm diff is cars equipped with the MYB transmission. MYB is the designation for the 6L50E. So V6 manuals get the larger diff too.(again thats according to my catalog)
Rear end gears 2Fast4U2010 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 01-26-2010 07:27 PM
rear end failure Mac the Knife Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 9 01-26-2010 09:51 AM
Help!!! Hearing a Strange Noises from rear end of V6 6 speed Bigred1981 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 10-17-2009 12:18 PM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 01:06 AM
Rear end whine while under load shiftz33 5th Gen Camaro SS LS LT General Discussions 4 08-12-2009 05:15 PM
