![]() ![]() ![]() Drives: 2010 IBM Camaro SS Join Date: Jun 2007
I'm trying to remove the oil filter on my SS but it just wont come off.
Lookup 'UP' at it I'm turning it counter clockwise which is usually how I'd 'loosen' something but it barely moves. I think I've got it maybe 1/2 a turn but it just doesnt seem to be coming off. My Filter top wrench doesnt fit this stock filter so I'm having to do it the hard way. Considering you usually do just over hand tight to put new ones on I dont understand why this one is so tough. Any tips on this? (and am I doing something wrong?) |
I am the internets.
Try grabbing it with a piece of sandpaper. Works every time for me, I don't even use a filter wrench.
Normally I wouldnt need a wrench either but this one almost seems welded on. This is the first one I've done in a few years though.
I am right in assuming they come off in the same direction a normal nut would? (counterclockwise to loosen) |
![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: May 2009
I didn't change the oil on mine, but can you try and get it with the old strap wrench kind?
![]() ![]() ![]() Drives: 2010 Camaro Join Date: Aug 2009
Leftey loosey, Rightey tightey
#6 |
Guest
I haven't changed the oil on mine yet ,but I usually put a screw driver through side of them and use it to loosen tight ones. I don't know if you have room to do that as I haven't even looked at the underside of mine yet. If not get an oil wrench that fits.
#7 |
Finally got it. Hammered a screw driver through it and wrenched it off. Man that thing was over tight.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: RSSS Join Date: Dec 2009
#9 | |
![]() Drives: '10 Camaro 2SS,04 Colorado,06 ZX6R Join Date: May 2008
![]() As for removing it - sandpaper works great, a rubber jar opener can work too. It is LEFT (county clockwise - I have changed my oil a couple times now) The stock one was definitely tough. If those methods are unavailable or don't work, warm up the motor. It will be hot, but things tend to loosen up. Try turning it (I'd wear gloves made for heat) - see if you can get it loose, then let the car cool down a bit before removing the rest of the way. However - this is of course a huge problem if you already drained the oil which is the procedure I always do, drain oil then take filter off. A pipe strap will work too if you have one of them.
Vararam CAI, ARH Headers, Flowmaster Exhaust, Nitto NT555Rs, Custom CAM and Tune - 11.981 @ 116.27
![]() IOM - 2SS/RS - Auto - IAP - Sunroof - Ordered 10/13 (#7 at dealer) 3000(accepted to production ): 4/19/093300 (scheduled for prod ): 5/11/093400 (broadcast ): 5/16/093800 (produced ): 5/22/094150 (invoiced ): 6/01/094200 (shipped ): 6/01/095000 (at dealer ): 6/12/096000 (delivery to me ): 6/12/09 |
#10 |
Good to hear - the stock ones may all be very tight, I know mine was a PITA to get off.
#11 |
Petro-sexual
I hate when that happens. I've had to resort to chizzeling off a filter before too, after doing all of the above. What a PITA... Good job getting it off
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
#12 |
Guest
Good point about the inverted filters. I keep forgetting some cars have the goofy set up. I wouldn't be that worried about side mounts. Not a very good chance of metal getting in motor with that.
#13 |
SoCal C5 Family Member
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M Join Date: Jul 2009
That's why I've been replacing with these:
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers; |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Was your engine hot?
A cold filter will be stuck on like concrete. Get the motor nice and hot from a long drive and grip it with a quality filter wrench. |
| best synthetic oil to use | hollywoodjose | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 130 | 01-26-2014 09:51 AM |
| V6 Oil FIlter | dagolfguy | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 33 | 03-27-2010 10:38 AM |
| 1SS V-6 OIL PLUG LOCATION ? | Brendon | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 15 | 01-29-2010 01:05 PM |
| Pure Power Reusable oil filter | Parker | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 2 | 06-23-2009 10:03 PM |
