Old 02-24-2010, 08:24 PM   #1
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
c6 z06 brakes
has anone tried to put c6 zo6 brakes on the camaro either lt or ss i saw them on a sema car at the show so i was wondering if anyone has used them or researched it
camaro4mybday is offline   Reply With Quote
Old 02-24-2010, 08:26 PM   #2
Indpowr
Drives: Corvette C6
Cheaper to by 6 piston Stoptech or there of.
Old 02-24-2010, 08:30 PM   #3
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
Why? The Brembo's do better slowing the Camaro down than the Z06's do for itself. Z06 owners should probably be the ones switching to our breaks.
Kyle2k is offline   Reply With Quote
Old 02-24-2010, 08:32 PM   #4
Indpowr
Drives: Corvette C6
I assume your joking...
Old 02-24-2010, 08:54 PM   #5
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
No...I'm not- look at the 60-0 times. (and don't forget the fact the Camaro is carrying around 500 more lbs) The only person that cares if you have 4/6/8/12 piston breaks is the idiot at the car show that never really drives his car. There are some benefits, but not enough in my opinion...and if anything, the Camaro's brembos are still alot better than the Z06 breaks...which is what the OP is talking about.
Old 02-24-2010, 11:23 PM   #6
Indpowr
Drives: Corvette C6
PBR - Z06 brakes are amazing but for the money he can go with 2 piece (lighter rotors = less unsprung weight) plus stoptech/brembos would be a killer setup for less money.
I like to see some data how you can state that a 4 piston stock brembo is better than than a stock PBR Z06 6 piston.
Old 02-25-2010, 09:21 AM   #7
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
Look at the magazine reviews for both cars, the SS brakes are slowing a car down that is 500 lbs heavier in the same/shorter distances than the Z06 and shows less fade...where is your data? Obviously a flow blown aftermarket 2 piece rotor set with brand name calipers are going to be better than either of the above...but to the OP that thinks its worth swapping...its not.
Old 02-25-2010, 12:47 PM   #8
scomaro22
scomaro22's Avatar
Drives: 2010 VR 2SS! ,'09 Genesis
2010 Victory Red 2SS 20" Polished Wheels
Delivered 8/3/09 !!!!!!!!
scomaro22 is offline   Reply With Quote
Old 02-25-2010, 08:04 PM   #9
Chris_B
Chris_B's Avatar
Drives: Several
You are correct, sir. Not to mention the Brembo's, while not the high-end aftermarket Grand Turismo variety, won't have the instant death fade the C6Z brakes suffer from. They will definitely fade when pushed hard, but they will give more warning than just using the nearby K-rail.
Chris_B is offline   Reply With Quote
Old 02-27-2010, 07:27 PM   #10
Buelligun
Buelligun's Avatar
Drives: 2SSRS manual yellow black stripes
I've had my brakes begin to fade whilst undertaking a bit of 'spirited' driving, I do not have a problem with the stopping power but, prolonged use does see a drop in effectiveness-I think drilled and grooved rotors will allieviate the problem!
Buelligun is offline   Reply With Quote
Old 03-01-2010, 08:22 AM   #11
Shifty 6
Drives: 2010 GTI
Some of us are confused...is the OP breaking his brakes? If he is breaking his brakes, maybe he does want to look at getting something better?
Shifty 6 is offline   Reply With Quote
Help, looking for a c6 z06 repair manual RoyalKev General Automotive + Other Cars Discussion 0 01-07-2010 02:15 PM
z06 brakes????? blackedout010 Wheels and Tires Talk Sponsored by The Tire Rack 25 05-18-2009 01:40 PM
