![]() Drives: 2010 Cyber Grey 1LT Join Date: Feb 2010
El Wire footwell lighting and Led dome light
I combined tips and ideas from several threads to come up with this interior lighting combo for the Wife's Camaro 1LT.
I gathered a lot of information from the footwell DIY thread found here. I personally thought the footwells were too bright for my tastes, so i used El Wire instead. I used two 6' sections of blue El Wire, one for the drivers and one for the passengers side. One six foot section looks like this in the dark: ![]() I took a piece of plastic and drilled holes in it to match the openings in the top of the footwells that GM placed there. These are the same holes used in the thread above. I used glue and wrapped the Elwire around itself so it would take up less room. Here is a picture (sorry it's not the best quality) of it installed in the car. You can see one of the tie-wraps i used to hold it in place along with the EL wire connector. I ran power from the overhead dome light. ![]() I also replaced the overhead bulb with a blue LED from Rodney at Vizualize Automotive Options. Here is the overall result: ![]() Here is a close up of the footwell lighting. The towel on the floor is white; i wanted to show off what color light the EL wire is giving out. ![]() I think the end result is pretty cool.
Wow, that is cool, great job!
2 SS CGM RS, IOM interior, Customized by Clean Cut Creations St. Louis, MO
![]() ![]() ![]() ![]() ![]() Drives: '10 Camaro 2SS/RS & Magnum R/T Join Date: Oct 2008
There is a thread somewhere that states that you dont need to run power from the dome.
SIM Camaro 2010 V8-2SS/RS-A6!!+
www.Camaro5store.com
Looks great! I was actually planning on using the El Wire for pretty much the same thing in the trunk....only, after a while, knowing that the el wire was not that bright, I figured I'd need either high wattage El Wire or a LOT of EW. So...I kind of put it off.
I think I'm going to start on the glove box mod first....wrapping a bunch in there like that so I can actually see in there. |
Nicely done!
Camaro 5 Fest here I come!
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
Cool!
🔺22 RS E TRON GT
🔺21 Model S Plaid |
| DIY - Footwell LED lighting In tune with Dome Light | markmass | Camaro DIY & HOW-TO instructions & discussions | 52 | 09-03-2010 08:00 PM |
| Just installed footwell lighting. | SSTony | Camaro DIY & HOW-TO instructions & discussions | 4 | 08-01-2010 09:37 PM |
| Footwell Lighting on my IOM | ttexxan | Cosmetics and Lighting Modification Discussions | 2 | 02-15-2010 10:53 AM |
| Yet another Footwell Lighting question | rmnc3r | Cosmetics and Lighting Modification Discussions | 2 | 02-01-2010 01:47 PM |
| LED Interior and Exterior Lighting. | SummoneR | Cosmetics and Lighting Modification Discussions | 101 | 08-17-2009 09:01 PM |
