3rd gear release...
Does any1 have 3rd gear release way to early down the clutch??
All it takes is for me to put my foot on the clutch and push an inch down and its out... all other gears need the clutch at least half way...
SHOCKWAVE - 2SS/RS/M6 - Blk/Blk
JRE Tuned - ARH LT 1-7/8 w/Cats - JRE Rear 4.11 - Borla "S" Cat-Back - CAI by CAI - H&R drop - HURST Shifter - BMR Tunnel Brace; 4 Point Brace; Adjustable Toe Rod; Rear Trailing Arms - Sphon Control Arms - MTI Racing w/Fire Sleeves - Stealth Ambers - GTS Tails - Phantom Grille - Concept LED Sidemarkers - Blacked out logos - Hotchkis Bars & End links - BMR Front Driveshaft Loop (install soon) - BMR Subframe connectors (install soon) http://www.cardomain.com/ride/3813191# |
![]() Drives: 2010 2SS Join Date: Jan 2010
Is this with the stock shifter?
If so, this is not normal, go to dealer, do not pass go. If you or someone installed an after-market shifter and this trait happened after the install. I would have another look underneath. Did the bottom boot get fully installed? It's one of the tough things to put back if you have large hands. If it is hanging it could mess-up the shifting.
Installed options;Tinted Windows, De-badged, Hurst Shifter,CAI,Vmax throttle body, Kooks LT Headers, High Flow Cats,Borla Touring Axle Back, ADM Scoop, Washwater relocation,Diablo Predator(c/w Ted's Magic), Custom start defeat switch, painted engine cover, shark fin & bow ties, ABL lighting, Rear Camera. |
yea.. stock shifter... M6... never been opened...
High on "The Camaro Life"
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam Join Date: May 2009
Try this, drive in third gear at high rpm's. Hold a little pressure back on the shifter and now let off the gas. It will pop right out of gear, without even using the clutch. That's normal, because of the slack created in the gears just as you let off the gas. How do you think that Semi drivers shift without the clutch? They just time the shifts to the slack in the gears created when decelerating and accelerating. It is just alot easier to do in the higher gears.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby... thats soooooooo weird!! i can do it in 3rd and in 4th too... not gonna keep trying.. don't wanna hear any grinding that hurts the heart....
thanks for the info though!
| 3rd gear no longer smooth on M6 | ittybittyfds | 5th Gen Camaro SS LS LT General Discussions | 45 | 03-28-2010 02:30 AM |
| Does any 6 speed owners see a need for a gear indicator? | OHIOSS | 5th Gen Camaro SS LS LT General Discussions | 98 | 10-13-2009 09:36 PM |
| problems shifting into 3rd gear | tom692010 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 16 | 09-02-2009 03:22 PM |
| Do you think it was right that the mustang got to use the trackpack in the comparison | perfxn | Chevy Camaro vs... | 91 | 03-30-2009 10:44 PM |
