Old 08-27-2009, 12:18 AM   #1
tom692010
Drives: 4 wheels
problems shifting into 3rd gear
I've been at the drag strip 2x now and this second time around I wasn't able to get it into 3rd gear. It should be an easy enough thing to do. I'm not overly pushing the shifter to one side. It seems to be harder than expected when I shift normally also. Does anyone know of an issue like this with the manual tranny. I'm not that bad at shifting either. I gave it 4x before I called it quits. Any help would be appreciated.
tom692010 is offline   Reply With Quote
Old 08-27-2009, 10:26 AM   #2
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Hmmm...
don't tell GM that you were drag racing... But it could be a syncro...
Does it grind? or just hard to get into the detent?
Old 08-28-2009, 09:32 PM   #3
peel out
Peel Out
peel out's Avatar
Drives: 2010 2SS/RS Inferno Orange 6sp
2nd gear!!!!!!!!!!
I am having problems getting it into second gear. Its not a normal pull down. Anybody else having issues with 2nd?:(
peel out is offline   Reply With Quote
Old 08-28-2009, 11:09 PM   #4
gtwss
Time To Hammer Down
gtwss's Avatar
Drives: 2010 Camaro SS, 02 Monte Carlo SS
Is it going 1st to 4th on you? If so, you are dealing with the skip shift.
2SS, CGM, M6, Polished Wheels
6000 8/13/09
gtwss is offline   Reply With Quote
Old 08-28-2009, 11:15 PM   #5
Inspector 17
I love crepes
Inspector 17's Avatar
Drives: 2017 ZL1 NGM A10
Sounds suspisciously like skip-shift. Watch the DIC next time it happens.
To the OP, can you descriibe the issue a little more? It is just during a run that you are having problems? What RPM range are you shifting at? As GTAHVIT asked, any associated noises?
Inspector 17 is offline   Reply With Quote
Old 08-28-2009, 11:35 PM   #6
gtwss
Time To Hammer Down
gtwss's Avatar
Tom692010.... sure you just didn't miss 3rd I know I have, need more info
6000 8/13/09
Old 08-30-2009, 09:24 PM   #7
hiller72
Drives: 2010 2ss/rs camaro
Yes I am having trouble with second gear as well. If i run it right to 6200 and try a quick shift to second it grinds until RPM's come down.
hiller72 is offline   Reply With Quote
Old 08-30-2009, 09:27 PM   #8
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
I am also having trouble between 2nd and 3rd. I did replace my shifter with MTI racings six shooter and got a little improvement but I too still have like a slight grind going into 3rd. Whats up GM???
lawdogg149 is offline   Reply With Quote
Old 08-30-2009, 09:31 PM   #9
camaroincarolina
camaroincarolina's Avatar
Drives: 1SS Aqua Blue Metallic
Get the skip shift eliminator and have it installed....no more problems. Call Jeff at allusamotorsports.com
camaroincarolina is offline   Reply With Quote
Old 09-01-2009, 11:22 PM   #10
LS 1st gen
Kept the Faith.
LS 1st gen's Avatar
Drives: 2010 VR 2SS
Send a message via AIM to LS 1st gen
I don't think this is a skip shift issue. The 3rd gear engagement throw is pretty clunky even when skip shift is not activated.
SOLD 2010 Camaro # 13694 Victory Red 2SS manual | White rally Stripes | Polished Wheels | Rotofab CAI| MGW Shifter| Kooks LT's| Magnaflow X-pipe|FM 40 Delta Flows | Elite Tunnel Brace | "Ginger"
LS 1st gen is offline   Reply With Quote
Old 09-01-2009, 11:51 PM   #11
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
2-3 synchros and blocker gone..you likely over revved and or missed a shift.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 09-02-2009, 10:31 AM   #12
peel out
Peel Out
peel out's Avatar
2nd gear
No its not the skip shift, Its when i am slowly going into 2nd gear from first. Its not all the time, Its as if i didn't pull stright down from first, but i did pull stright down, I have to go into nutural then go into 2nd to get it to work.... I am a girl so i am explaining it in a girly way.
Old 09-02-2009, 02:04 PM   #13
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
dont go slowly into second....
I piss excellence
and fart awesomeness
Old 09-02-2009, 02:07 PM   #14
GTAHVIT
Blessed
GTAHVIT's Avatar
he's being serious BTW...
Difficulty shifting into 3rd djsnoflake V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 45 03-29-2010 01:08 AM
Shifting problems sebardin 4th Generation Camaros 6 08-09-2009 09:03 PM
Do you think it was right that the mustang got to use the trackpack in the comparison perfxn Chevy Camaro vs... 91 03-30-2009 10:44 PM
COMPUTER AIDED GEAR SHIFTING?? SLIMJIM 5th Gen Camaro SS LS LT General Discussions 12 02-09-2009 07:24 AM
