Old 02-28-2010, 04:51 PM   #1
spryc5
Drives: iom 2ss
what kind of gas v6?
i was wondering what kind of fuel you all use in your v6s?
spryc5 is offline   Reply With Quote
Old 02-28-2010, 04:55 PM   #2
mulehead7
stubborn as a ...
mulehead7's Avatar
Drives: '94 Trans Am
regular 87 octane should get you where you're going. If you got money to burn you could put in 89 octane put its not necessary.
Welcome to Camaro5!
mulehead7 is offline   Reply With Quote
Old 02-28-2010, 05:01 PM   #3
2SuperSport
2SuperSport's Avatar
Drives: 69-SS/RS 10-2SS/RS 02-GT
i dont own a V6 but i would assume that the timing will adjust to whatever octane level you decide.
I also have a S/C frontier (beater) that recomends premium. I use 89 and it runs fine.
2SuperSport is offline   Reply With Quote
Old 02-28-2010, 05:01 PM   #4
spryc5
Drives: iom 2ss
my car runs real well on 87. just a ? i love my car every thing i want it to be. i traded a 1999 corette vert. on this,but this is more driveable. has plenty of power for me. i have drove v8s but i did not like the way they shift,gess this can be fixed.
Old 02-28-2010, 05:05 PM   #5
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I run 91 in mine ...
Old 02-28-2010, 05:07 PM   #6
markbolt
Drives: 2010 2SS Camaro
Cool
The manual is a handy device. regular
markbolt is offline   Reply With Quote
Old 02-28-2010, 05:09 PM   #7
spryc5
Drives: iom 2ss
i know what the book says. the ? was what do you do. du
Old 02-28-2010, 05:11 PM   #8
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
The car will run fine on 87 although it appears the that knock sensors are pretty active when running 87... running a higher octane gas reduces the knock sensor activity, so in theory allowing for more timing and improved performance... now whether you can actually feel the difference that is up to you to decide... I know my car feels more peppy with premium and I know I don't see nearly as much knock retard as I do with 87...
and yes I run 93...
scrming is offline   Reply With Quote
Old 02-28-2010, 05:16 PM   #9
spryc5
Drives: iom 2ss
and yes I run 93...
you have a very nice looking auto. great job.
Old 02-28-2010, 05:20 PM   #10
scrming
scrming's Avatar
Thanks...
Hopefully a few more appearance mods this spring...
Old 02-28-2010, 05:27 PM   #11
scrming
scrming's Avatar
Originally Posted by ontheaccount View Post
Maybe a dumb question Scrming, but what are knock sensors?
Ok... are you familiar with spark knock or pinging?
Knock sensors can "hear" the spark knock/pinging/detonation before you can actually hear the sound in the cabin... When they detect what they think is spark knock they will start to pull/reduce timing, which should eliminate the spark knock but also reduces performance...
I have a Dashhawk, which I uses to monitor the cars computer.. one of the things I watch is "Spark Retard" which is the amount of timing the knock sensors are pulling/reducing.... I made a short video showing how active my knock sensors are when I run 87 octane... the spark retard is in the bottom right corner:
Old 02-28-2010, 05:34 PM   #12
spryc5
Drives: iom 2ss
Smile
that is great thanks for that
Old 02-28-2010, 05:53 PM   #13
spryc5
Drives: iom 2ss
will car adjust for dif gas higher oct?
Old 02-28-2010, 05:59 PM   #14
scrming
scrming's Avatar
yeah... sort of... basically it appears the the computer doesn't reduce the timing as much with higher octane, so in away it is adjusting for it...
How does your modification accept your gas mileage? Heelhook22 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 12-15-2009 09:16 PM
4th Gen. Z28 to 5th Gen. V6 tryan2422 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 27 11-11-2009 09:20 AM
GTA V6 Owners...Need Help TJ91 Canada 8 08-23-2009 06:22 PM
What kind of gas will she come with? perfxn 5th Gen Camaro SS LS LT General Discussions 48 04-13-2009 11:53 AM
Fuel pump or bad tank of gas? Boomer Sooner 4th Generation Camaros 25 01-02-2009 07:34 PM
