Old 03-01-2010, 03:33 PM   #1
convert
convert's Avatar
Drives: the Camaro as often as possible
Too backwoods-y oil change plan
Ok, so I picked up a 6qt case of Mobil 1 at Costco over the weekend for $32, and a K&N filter at O'Reilly's for another $14. I've got the V6 so changing the filter is easy, but I still need a way to get under the car to drain the oil. I don't have ramps, and have had bad luck trying to get the front of a RWD up on ramps in the past (they slide), so I'm thinking of just running the front of the car up on the sidewalk next to my house. It's got those rounded curbs, so I could just drive up it. Also, with the crown in the road I think the car will still be pretty close to level, at least closer than if it was on jacks or ramps in the front only.
So my 2 questions are, does that sound like it'll work? Sounds ridiculous I know, but it's a little dead-end road to nowhere to it gets 0 traffic. And is it important to have the car level for good drainage, or is it ok to have the front end in the air?
convert is offline   Reply With Quote
Old 03-01-2010, 03:38 PM   #2
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
Hit the walmart for some ramps. They have a set for 40.00-ish and they have rubber pads on them to stop slippage (on everything but my composite garage floor that is). I don't think you will have enough room in your scenario....and it certainly won't be any fun if you do manage to get under there and not have ample room to work.
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 03-01-2010, 03:48 PM   #3
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
Yeah I am gonna say no bueno on this one. You are gonna run the rish of messing up your front valance. I say just suck it up and get some ramps. I built the ghetto DIY wood ones and while they work I didnt like them. I have some race ramps on order now. If you do the ghetto ones make them out of 2x12 or 2x14.
Cheers
K
Moriartii is offline   Reply With Quote
Old 03-01-2010, 04:07 PM   #4
pleigh
pleigh's Avatar
Drives: 2010 CGM 1LT A6
Cheers
K
I agree,
These work great, they did this on Mustangworld before. You can basically take 2x10 or 2x12 lumber and cut to descending length and nail them lined up on one end longest on bottom, shortest on top. Cost to make: Around $30 in wood
Materials: 2" x 10" x 10 foot (two), 2" x 10" x 8 foot (two) and a 2" x 3" x 10" piece.
I think some folks have posted a couple of threads on here about it too.
1LT A6, 19" polished rims, MRT 1.0 exhaust, Boston Acoustics, C&C package, Tint
NO, the Rev limiter is not set to 118MPH... and YES, driving in this manner does affect MPG...
pleigh is offline   Reply With Quote
Old 03-01-2010, 04:17 PM   #5
2010 2-Tone
Drives: 2010 RY 2SS with Custom Stripes
Get the low profile ramps, they work great and you won't break the bank. As Hypurone says, they have rubber pads on the bottom and usually won't slip. Mine works just fine.
2010 2-Tone is offline   Reply With Quote
Old 03-01-2010, 04:53 PM   #6
convert
convert's Avatar
Thanks for the input. I'll check WalMart for some ramps. I know I can get the car on the curb w/o damaging the valance, because it's the same kind of rounded curb that I have to drive up to get into my driveway. But ramps are nice -- especially if it's raining out and the street is wet.
Old 03-01-2010, 08:17 PM   #7
jputer
jputer's Avatar
Drives: 2016 1LT Garnet Red
I don't have a picture of the front up yet, just the back. If your garage floor is too slick, put a small piece of rubber backed carpet (door mat, dish drainer or anything rubber) under the middle of the ramp. I love my ramps....
2011 1LT/RS Summit White A6
jputer is offline   Reply With Quote
Old 03-01-2010, 09:05 PM   #8
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
Originally Posted by pleigh View Post
I agree,
The nice thing about steel ramps is the pocket that won't let the car roll forward or back off the ramp top.
Which is nice as you can drive up the front, then jack up the back to get lots of room or even just to help get the front end up high, as it can be scary jacking up the front real high.
2ndgenz28 is offline   Reply With Quote
Old 03-02-2010, 12:21 AM   #9
convert
convert's Avatar
Hey, I like those black painted cans!
Old 03-02-2010, 12:22 AM   #10
convert
convert's Avatar
Oh, and one other thing -- does it matter if the front is higher than the rear during the change?
Old 03-02-2010, 02:37 AM   #11
jmaryt
Drives: 2010 cgm LS
i got a better idea!..at least for me!..my selling dealer will change oil and filter for 17.99..screw it!..let 'em do it for that money!..
jmaryt is offline   Reply With Quote
Old 03-02-2010, 03:15 AM   #12
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
depends on where the drain plug is.
Old 03-04-2010, 01:01 PM   #13
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Just use a floor jack. Lift the car, remove the plug, lower car and let it drain. Lift car, replace plug, replace filter, lower car & fill.
[Don't forget to throw a jack stand under the car before crawling under]
Old 03-10-2010, 10:24 AM   #14
calflan
calflan's Avatar
Drives: 1LT; IBM; 6 Spd Manual
Please don't crawl under there with just a floor jack holding it up !
NEVER rely on a floor jack alone. If you use a jack stand, use 2 ea. One on each corner.
The only issue you'd have with using the curb is the front valance. If that clears good, no problem, same as using ramps.
... BUT, you're buying K & N filters for $14 when the GM filter is about $6. If you like spending money on things like a K & N, buy the right tools for the job as well. Get a set of ramps. You'll find you use them more than you realize. If you just want to check underneath for exhaust, suspension, etc. system inspection, the ramps are VERY useful.
1LT; Airaid CAI; Flowmaster American Thunder Axelback; Int Floor Lts; RS Spoiler; Radio Controls; Sequential tail lights; Oil Catch Can; VMAX Throttle Body; MACE plenum spacer; Mace manifold insulator[/I]
calflan is offline   Reply With Quote
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
Car "waking up" after oil change..is this due to the fuse pull? CamaroFemme 5th Gen Camaro SS LS LT General Discussions 6 10-05-2009 04:44 PM
Early oil change...How do you know that you have reset the oil life system? Rob53 5th Gen Camaro SS LS LT General Discussions 6 08-23-2009 02:23 PM
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 08:25 PM
