Old 03-07-2010, 12:52 AM   #1
Bogey99
Bogey99's Avatar
Drives: 2013 ZL1 Black M6
Lightbulb K&N Intake and Tune Results
Posting the dyno results of the K&N Typhoon and a tune.
Green obviously being the baseline.
Bogey99 is offline   Reply With Quote
Old 03-07-2010, 02:05 AM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Thanks for the info.
That's a far cry from the advertised 18hp/18tq for the CAI alone.
Did you happen to get the fuel trims off the PCM? How bout knock?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-07-2010, 02:43 AM   #3
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
its 18 and 18 at the flywheel isnt it? thats what i assumed...
The 2010 Sin is offline   Reply With Quote
Old 03-07-2010, 03:05 AM   #4
Bogey99
Bogey99's Avatar
Post
These are the only other charts that I have. Tuner said that the near 90 degree bend along with hotter induction temps in the K&N is what kills it. An over the radiator looks like the way to go, I think the gains from this particular intake is very minimal. Looks good and sounds good, thats about it. Although, it may prove more valuable as more modifications are done to the engine ie. cam and headers.
sorry, not sure how to make these charts smaller.
Old 03-07-2010, 05:32 AM   #5
axis
Search Ninja
axis's Avatar
Even 18hp at the flywheel is a far cry from the posted results. Considering a good tune will net you around 5-10hp, that means his K&N gave 7-12whp.
It's not the 90 degree bend so much as it is the heatsoaked metal intake tube. It's well known that metal intake tubes in a hot engine bay don't go well together. If they would have logged IAT's, it would have shown this.
Halltech CF 102 fed
Old 03-07-2010, 06:01 PM   #6
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
K&N CAI's suck, other companies have a bigger tube and are plastic.
Old 03-07-2010, 06:02 PM   #7
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
They make a plastic tube version.
Old 03-08-2010, 12:51 AM   #8
Bogey99
Bogey99's Avatar
All said and done, I think an over the radiator intake is the only way to go if you want to gain more than just a few horses. An over the radiator goes almost straight into the throttle body and intakes cooler air = horsepower. I can tell you one thing for sure, the K&N is not good for much horsepower because my baseline dyno before the tune (with the K&N) is consistent with stock numbers +/- a couple HP. I had good hopes for the K&N Typhoon but I just simply would not recommend this intake based on my findings.
I cant speak for the plastic ones that have a fully enclosed compartment where the stock airbox used to be. I would be curious to see numbers on one of those.
Old 03-22-2010, 04:21 PM   #9
ilovehooters1385
ilovehooters1385's Avatar
Drives: 2010 Camaro 2SS/RS
the 63 series, is the black one which it says its made out of something thats not medal the word looked like a form of plastic to me lol
am i wrong? isnt that the problem yall are saying is the heat from the metal pipe?
ilovehooters1385 is offline   Reply With Quote
Old 03-22-2010, 04:29 PM   #10
Legend
Hello!
Legend's Avatar
Drives: 2008 JSB Z06!
Would a metal/polished tube with a sealed box have the same results?
If so, I guess the metal/polished tube is more for looks then while the plastic tube would net the bigger gains and prevent higher IATs?
Legend is offline   Reply With Quote
Old 03-22-2010, 05:42 PM   #11
axis
Search Ninja
axis's Avatar
It is a problem with the metal but the plastic version has a huge indented hole where the MAF goes. No one knows why they made it that way but it's got to kill airflow.
Halltech CF 102 fed
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3653 07-28-2025 05:56 PM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 10:40 AM
Does K&N intake require a tune? gtothep123 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 02-02-2010 09:14 PM
Track Results are in for 2010 CAMARO SS w/ cold air intake & ecu tune!! Late Model Racecraft Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 45 05-14-2009 07:23 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 09:10 PM
