Old 03-08-2010, 07:01 PM   #1
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
5 point seatbelt harness
Does anyone make a 5 point seatbelt harness for the 2010 Camaro?
And what kind of modifications are involved with installing one?
I'm thinking it will help out on roadcourse track days.
stratman2SSRS is offline   Reply With Quote
Old 03-08-2010, 07:11 PM   #2
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Must be. There's a post here - I think under race seats - where some is showing their race harness...
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 03-09-2010, 07:52 AM   #3
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
I haven't seen a harness on here myself, that doesn't mean there isn't. But I got one of the CG Locks for my seatbelt. It helped a lot with autocrossing. Definitely not a harness but better than nothing.
1977and2010 is offline   Reply With Quote
Old 03-09-2010, 09:43 AM   #4
Michael_Js
Michael_Js's Avatar
I also have been using the CG Lock - well worth it! I'll try to find the harness thread...
Old 03-09-2010, 05:16 PM   #5
sik68
sik68's Avatar
Drives: 1968 Camaro, 2002 Subaru WRX
I have done a fair amount of research on proper use of racing seatbelts, and here are some points I have picked up. I'm not an expert and maybe paranoid...so take this for what it's worth.
1) You need a different set of seats that are made for harnesses. They would include holes for the shoulder straps, and a hole in the bottom for the crotch strap.
2) The seat should be fixed-back. A hinged seat has a chance to snap and you won't find one approved by the FIA.
3) To properly mount the shoulder straps, they should be connected to a harness bar for 2 reasons. 1) Minimizes the length of the straps, and thus the stretch they undergo in an accident. 2) if the shoulder mounting points create a steep angle of the strap, it creates forces on your body during an accident that tend to pull you down, which is undue stress on your body.
4) Depending on if you assume the roof of a 2010 camaro is stiff enough for a rollover in a racing situation, a 4-5 point system may be a liability if you don't have a rollbar or cage. This is because the harness forces you to sit upright during a crash, which potentially means you will be crushed in a rollover. With a standard 3pt, it allows you to bend at the waist away from the roof.
These are just some things to consider.
sik68 is offline   Reply With Quote
Old 03-23-2010, 05:58 PM   #6
stratman2SSRS
Thanks, that is some good insight.
That CG lock might snug things up a bit??
Old 03-28-2010, 10:32 PM   #7
NJSS
Drives: 2010 2SS RS - Inferno Orange 6 spd
You really need specific racing seats, a harness bar or roll bar and probably a 6 point harness system. Lots of companies make racing seats like Recaro, Sparco & etc. There is a lot of information on their web sites.
If you are only going to do an occasional track day, stick with the seats you have now. If you do 5 or more events a year (very addictive once you start) it may be practical. Sometimes racing seats are not the most comfortable or easiest to get in and out of.
NJSS is offline   Reply With Quote
Old 03-29-2010, 02:53 AM   #8
The 2010 Sin
Dont H8 Me Cuz U Aint Me
The 2010 Sin's Avatar
Drives: 2016 SS Sedan, 2017 Explorer Sport
schroth used to make a quickfit that i used on my BMW's that were fantastic... wish they stepped outside of the imports a bit
The 2010 Sin is offline   Reply With Quote
Old 10-17-2010, 09:21 PM   #9
John M.
Drives: 2010 Camaro
Send a message via AIM to John M.
The CG locks are OK but I still slid around. The harness bar is from Speedware Motorsports (Tony Pletcher 425-869-5680), and the belts are Schroth 6-point Hybrid II
John M. is offline   Reply With Quote
Old 10-17-2010, 09:36 PM   #10
John M.
Drives: 2010 Camaro
By the way. If you plan on tracking the Camaro you may want to do some prep work:
I melted Hawk HP Plus pad, just ordered Hawk DTC-3o for 10/23 track weekend.
I also set my alignment to:
Front camber -1.4degrees
Front Toe IN .06 Left and Right
Rear Toe IN .15 Left and Right
Old 11-06-2011, 04:48 PM   #11
ddunerider
So-Cal Race team!!
ddunerider's Avatar
Drives: Tahoe LTZ,2010 2SS/M6 Camaro
Send a message via AIM to ddunerider
Man I need this set up...
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!!
ddunerider is offline   Reply With Quote
Old 11-06-2011, 05:11 PM   #12
navyblueburnout
navyblueburnout
navyblueburnout's Avatar
Drives: 2010 Camaro 2SS
Proud member of the Never going back to Moderncamaro.com club!
navyblueburnout is offline   Reply With Quote
Old 11-06-2011, 07:49 PM   #13
600hp-lpe
Drives: 2010
you can use a 6 point harness and mount the bottom sub straps behind the drivers seat, and pass them between the bottom and back sections of the seat (so, basically you are sitting on the sub straps.
You will either need a floor mount shoulder strap or the speedware harness bar.
600hp-lpe is offline   Reply With Quote
Adaptive Fog Light DRL / Fog light Harness IN HAND Moonsault Interior Parts & Accessories 5 04-03-2011 01:35 PM
AAC DRL Connectors vs. Adaptive Performance Harness iomZL454 Cosmetics and Lighting Modification Discussions 20 03-07-2011 11:18 PM
The Plug & Play Harness for RS DRL & Fog Light are Ready Camaro21 Cosmetics and Lighting Modification Discussions 109 01-13-2011 06:32 PM
2010 radio replacement dask kit and harness strauchpete Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 21 02-02-2010 09:11 AM
At what point does a stock-car become a 'fast car' MrIcky Off-topic Discussions 13 12-28-2008 12:27 AM
