Old 03-08-2010, 08:08 PM   #1
ron10
Drives: 2010 2SS IOM L99
WHEEL SENSORS
has anyone had an issue with their wheel sensors?i put 36lbs.of air in all the tires.i have 3 tire gauges that all read the same,36lbs.when i am driving the car,i check the readout on the screen and it always shows a lower pressure in the tires.is there anything i can do to get the sensors to read the correct pressure?
Old 03-08-2010, 08:31 PM   #2
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
What pressure does the car show?
You do understand that tire pressure varies depending on temperature, right?
Fquick.com/NineBall
Old 03-08-2010, 08:32 PM   #3
viper1cobra
Member Club Elite #131
viper1cobra's Avatar
Drives: 2017 50th Anniversary H50 2SS
I have also noticed that they are not always accurate.
viper1cobra is offline   Reply With Quote
Old 03-08-2010, 08:38 PM   #4
ron10
the car will show like 34lbs.in three tires and maby 32 in another.but the readings will be different at different times.and the tires are hot.if anything the pressure should show higher.
Old 03-08-2010, 08:47 PM   #5
Nine Ball
Nine Ball's Avatar
I'd trust your tire gauges then, and disregard the cheesy GM sensor system. To answer your question, no there isn't a way to reset or recalibrate the sensors themselves. The only method is to take another chance and replace them with new sensors.
Waste of time. Gauges work better. Rely on the sensors to tell you when you have a really low pressure, they will set off a error message on the info screen if they get too low.
Tony
Fquick.com/NineBall
Old 03-08-2010, 09:13 PM   #6
ron10
thanks.it is not a major issue.just anoying.
Old 03-12-2010, 01:15 PM   #7
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
So is it the luck of the draw?
Mine are accurate. Last time I put air in them, I had my son sit in the car and tell me what the readings were and had all of the car sensors say 36, drove around the block to bump them around a bit, set them to 36 again and then checked with a gauge. all read pretty much right at 36.
Recommended Tire Sizes for 2010 Camaro Nine Ball Wheels and Tires Talk Sponsored by The Tire Rack 367 04-23-2024 11:22 AM
CHANGING THE STEERING WHEEL (Not for the faint of heart) VT2CA Camaro DIY & HOW-TO instructions & discussions 28 09-19-2014 02:31 PM
Tires loosing pressure joepitt Wheels and Tires Talk Sponsored by The Tire Rack 22 12-11-2010 05:00 PM
POWDER COATED WHEEL EXCHANGE PROGRAM !! L@@k !! ProdigyCoatings Wheels / Tires 8 01-31-2010 09:17 AM
Anybody pulling their hair out to due wheel or tire change with your braking sensors! noom1108 Wheels and Tires Talk Sponsored by The Tire Rack 10 09-26-2009 08:21 PM
