Old 03-12-2010, 12:10 AM   #1
j0hnny007
j0hnny007's Avatar
Drives: 2010 2SS RS
what oil comes stock
so my camaro should be comming soon, next 2 weeks or so and i was just wondering what oil comes in the motor from the factory, i ordered a 2ss with manual tranny. thanks
j0hnny007 is offline   Reply With Quote
Old 03-12-2010, 12:39 AM   #2
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
They come with mobil 1 in it from the factory
2010 Hennessey HPE650 2SSRS Blk/Blk
Magnuson TVS2300,ported heads,cam,Hotchkis suspension. Weld 17”s, Mickey Thompson’s.
klatterblast is offline   Reply With Quote
Old 03-12-2010, 12:59 AM   #3
j0hnny007
j0hnny007's Avatar
Drives: 2010 2SS RS
maybe i should be more specific, does it come with synthetic oil from factory or regular oil? i have read that regular oil should be used for the break in period.
Old 03-12-2010, 01:22 AM   #4
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
Only the SS comes with Mobil1.
Read the cap on the engine.
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 03-12-2010, 01:25 AM   #5
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
2ndgenz28 is offline   Reply With Quote
Old 03-12-2010, 06:26 AM   #6
first one
first one's Avatar
Drives: SSRS - black, GFX, SSX wheels
Mobil 1 Synthetic
first one is offline   Reply With Quote
Old 03-12-2010, 06:49 AM   #7
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
5w-30 says the Owner's manual
5w-30 Mobil 1 Full Synthetic.
Old 03-12-2010, 07:14 AM   #8
Russell James
Russell James's Avatar
Depends on the honing method used. Modern plateau honing and modern rings do not require non-synthetic oil or any special break in oil. So on modern cars, synthetic is perfect to run from day one.
If someone rebuilds an engine with an older style of honing (sharp peaks) and older style super hard rings, then that engine would be better to break in with non synthetic oil.
All the performance LS engines come from the factory with Mobil 1 5w30. The V6 is regular 5w30 due to it's oil temp and intended use of the car is not going to require synthetic. The V8's if driven hard/competitively can easily get the oil temp above what is safe for non-synthetic oil. So they are required to run synthetic at all times from day 1 on.
Old 03-12-2010, 07:50 AM   #9
ron10
Drives: 2010 2SS IOM L99
ditto!
Old 03-17-2010, 11:48 AM   #10
wylde1
I am the Stig
wylde1's Avatar
Drives: Black w/ IOM stripe 1SS
+1 as well special additives are needed if you've built an engine with a flat tappet cam. over the years, Zinc and other additives have been phased out of modern engine oils because it's no longer needed. But a flat tappet lifter and cam need the zinc to help harden the surfaces and crate desired wear patterns. So nowadays you need break in oils or additive if you've built an engine.
Modern cars "break-in" period is almost a non issue. Machining and material techniques have nearly eliminated the need to break in an engine like you used to.
2010 Camaro - 1SS, Black w/ Orange stripes
wylde1 is offline   Reply With Quote
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
3,000 Miles - No "Metal Shavings" - Anyone Else? FNKNSTN 5th Gen Camaro SS LS LT General Discussions 48 10-06-2009 12:46 AM
Need Opinion on Oil Change 68blk/yel396 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 22 06-22-2009 12:02 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 01:28 PM
