Old 09-26-2008, 11:19 PM   #1
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Screw Vtec -- check this out!
Found this completely by accident while searching around for some info on OHCs....
It's a new OHC variable-lift design developed by Delphi.
The file says it'll be ready for production in 2010...and it's almost too easy to guess who they're building this for...
(hint: they mention "HCCI"....)
2step_vls.pdf
Old 09-26-2008, 11:23 PM   #2
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
ford?
headpunter is offline   Reply With Quote
Old 09-26-2008, 11:26 PM   #3
bballr4567
Drives: 2016 Camaro 1LT M6
Looks pretty cool.
bballr4567 is offline   Reply With Quote
Old 09-26-2008, 11:26 PM   #4
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
Delphi's still designing stuff?
2023 GMC Canyon Elevation
Old 09-27-2008, 12:06 AM   #5
headpunter
headpunter's Avatar
Drives: Man
they are independant now.
i still wanna know what this is supposed to be going into.
Old 09-27-2008, 12:33 AM   #6
Mr. Wyndham
As far as I know, Delphi (which spun off of GM some years ago) makes some of the stuff GM uses in their vehicles. And up until now, I don't think GM has any sort of variable lift technology. They've got cam phasing...but that's a timing adjustment.
Then the article mentions this thing's ability to work with HCCI...GM's the only company that's really looking into HCCI engines. The German's might be, too....but I don't think they buy from Delphi.
Overall...I thought this was a very interesting feature we may see on GM engines soon.
Old 09-27-2008, 12:35 AM   #7
headpunter
headpunter's Avatar
Drives: Man
hmm, so for DOHC engines, so unless the ls architecture gets the boot, this will only be available on v6's and the various inline engines and north star engines (which i think are already on the chopping block) which are offered
Old 09-27-2008, 01:36 AM   #8
Mr. Wyndham
Could this possibly be the first use of this design?
GM Media
Global engine family
GM’s small four-cylinder gasoline engines include displacements of 1.0L, 1.2L and 1.4L. The engines were designed with fuel efficiency in mind, including technology such as full variable valve timing that optimizes power and fuel efficiency across the rpm band.
More importantly, torque for these engines – the pulling power that is felt when accelerating from a stop – is generated at lower rpm, for strong, off-the-line launches and confident acceleration at all speeds. Supporting powertrain features, such as torque converter design and transmission gearing, accentuate engine power and contribute further to the feeling of performance.
All engines in the family have premium design elements that contribute to world-class smoothness and durability, including:
  • Dual overhead camshafts
  • Roller-finger follower valvetrain
  • Chain-driven camshafts
  • Flow-controlled oil pump
  • Piston-cooling oil jets
  • Thermal management
Old 09-27-2008, 11:34 AM   #9
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Nice find Dragon!
Old 09-27-2008, 11:52 AM   #10
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
good find Dragon.
I piss excellence
and fart awesomeness
Old 09-27-2008, 01:20 PM   #11
drivingincamaro
drivingincamaro's Avatar
Drives: 95 civic
ummm what is it? does it improve hp numbers?
drivingincamaro is offline   Reply With Quote
Old 09-27-2008, 01:22 PM   #12
FenwickHockey65
Yeah, but they were already in trouble when my dad retired from them in 2006...and since their incompetent management just keeps digging deeper holes...
Old 09-27-2008, 02:35 PM   #13
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Basically its another piece of tech along with things like AFM and DI that gives you better fuel economy when you are just cruising around, and power when you want it. I think.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Check in Europeans! Emher Europe 100 09-21-2018 07:32 AM
Check out my new wheels! Dave McFly Off-topic Discussions 10 04-28-2008 12:46 PM
check this jeep out maro&bird General Automotive + Other Cars Discussion 3 01-31-2007 12:25 PM
Great Prices/Seller on Ebay. Check this out. TAG UR IT Off-topic Discussions 4 11-21-2006 04:06 AM
