Old 03-18-2010, 09:30 PM   #1
Carlos Garza
Carlos Garza's Avatar
Drives: 2010 Camaro SS RS
tune a maggie with meth and 91 octane gasoline
I live in Mexico and gasoline here is only 91 octanes, so I'm looking for a safe way to install a SC and still be somewhat aggressive with the tune. I think meth could help us do this. So my question is...
Should we tune the car without the meth, keeping the car somewhat reach and injecting the meth at WOT or should we tune the car with meth at all times...
I forgot to mention I would like to run around 8 psi with a 3.6 pulley.
thanks guys!!!
Carlos Garza is offline   Reply With Quote
Old 03-18-2010, 10:55 PM   #2
jrpxxii
jrpxxii's Avatar
I would recommend not tuning for meth at all times because if you forget to check the tank 1 time and it runs dry, kapoooeee. I just had my car done and it is setup for WOT but can also be setup to inject all the time or be turned off completely and this car is capable of over 1000hp.
Old 03-19-2010, 12:02 AM   #3
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
I am in Sinaloa, MX right now and they have 92 Octane here and throughout Sonora and Baja also.
Anyways, tune for gas then you can switch to a more aggresive tune for the track or whenever you spray the meth.
What are you using for tuning? If using EFI Live you can use the E85 PE and timing tables using there COS and just use a toggle switch when you want to use the meth. If using HP Tuner you can use the IAT to add/retard timing when using the meth.
When on the methanol jump up to 10 PSI.
We are getting ready to go to the track as I type. Hoping for 11's all motor and 10's on the spray.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 03-19-2010, 12:15 AM   #4
Carlos Garza
this sounds like a good idea, I'll talk about it with the guy doing the tune...
dang!!! low 11s high 10s!!! are those numbers for a camaro? I hope you guys take your video camera...
Are you guys OK with the Premium gasoline in mexico? maybe I'm understimated our gasoline and its really good. We are using HPTuners Pro, and are planning on doing 2 tunes one for regular everyday driving and the other one for the track...
Thanks!!!
Old 03-19-2010, 12:24 AM   #5
SRT10KLLR
Thanks!!!
Puro de la Roja(Premium).
The Camaro was running 12.90's with just headers and a tune. Added a ADM cai and went 12.59. Added cam, heads, etc. went 12.09 last Thursday.
Search for some vids I have posted under my screen name.
What part of MX are you from?
Old 03-19-2010, 12:29 AM   #6
El Chorizo
Drives: 2006 Lamborghini Gallardo
Carlos,
I'm putting a meth setup on my car when I do the supercharger, should be another 3 weeks. I'll keep you updated with the progress, but we will be using the Snow Performance Stage 3 setup.
My friend has this setup on his CTSV and it has over 50,000 miles on the setup without any issues.
2010 Camaro 2SS, 700RWHP, 667RWTQ @ 9psi - 11.03@124 @ 3600 ft. elevation TVS2300, Ported Stock Heads, Ported TB, Comp Cam, RPS Twin Disk, Kooks 2" LT's, Kooks 3" Catback, Dual ZR1 Fuel Pumps, H&R Springs, Barton STS, Hendrix Axles, BMR Trailing Arms, Snow Methanol Kit, Rotofab CAI.
2006 Lamborghini Gallardo, 2006 Cherokee SRT8.
2014 Mercedes CLA (On Order) / CLA Forum
El Chorizo is offline   Reply With Quote
Old 03-19-2010, 01:05 AM   #7
Carlos Garza
I live in Monterrey, and the last time I took my car to the track in ran a 12.9x with nothing but a tune, check my vids, ( www.youtube.com/cgarza12 ). I use to have a Charger SRT8 running low 12s with cam and heads, and decided to go with a SC this time.
Where exacly are you from?
Originally Posted by El Chorizo View Post
Carlos,
This is good to know, I guess I'll ask for the stage 3 kit and please keep me posted on your car.
Old 03-19-2010, 02:47 AM   #8
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
Thanks!!!
Heres a video from sinaloa, mx
JM
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
Old 03-19-2010, 01:51 PM   #9
Carlos Garza
JM
Awesome car, I've seen that vid before in another forum. Is that your Camaro? how much PSI are you running in it? is it running on 100% mexican premium gasoline? Who did the tune?
thanks man...
Old 03-19-2010, 04:55 PM   #10
Mike@DS
Drives: 99 Z28
+10000
Use it as a safety net, but I would not recommend tuning for the meth 100% of the time...
Mike@DS is offline   Reply With Quote
Old 03-19-2010, 06:13 PM   #11
Carlos Garza
Originally Posted by Mike@Diablosport View Post
+10000
Thanks a lot for the advice, that's what I'm going to do. Please say hi to Johan for me...
Old 03-20-2010, 04:37 AM   #12
JM10
Se habla espaņol
JM10's Avatar
No thats not my car, I bought an edelbrock SC from Stillen. Hopefully I will get it the first week of april, then going to take it to Sean from Top Gear Motorsports in Phoenix. I want to be as close as possible to 600rwhp.
2010 VR 2SS/RS
Hendrix HD Axles
DSS Aluminum Shaft
LPE ZR1 Clutch
Old 03-20-2010, 12:52 PM   #13
SRT10KLLR
thanks man...
That is my cousin's car and he is running about 14PSI on VP 109 plus a 100 shot of nitrous. Miguel from Guadalajara did the tuning you probably know him.
Old 03-21-2010, 01:16 PM   #14
Carlos Garza
Are you talking about RED?
