![]() Drives: 2SS/RS M6 RJT Join Date: Dec 2009
Where is the closest track to me for 1/4 mile times?
I live in Connecticut. From what I understand local tracks require that a roll bar be installed in the car. Are there tracks where amateurs can drive for 1/4 mile times? I would gladly take a road trip this summer to give it a try.
[SIZE=1]2SS/RS/MN6/RJT/Beige/Sun Roof
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Here's a drag strip locator. You can search for a track near where you live. http://racingscenemag.com/races/dragstrips.htm Your car should be fine to run down a 1/4 mile track. At the very most you might need a helmet. Our track rents helmets if you don't have one. Also I run 12.5s and I've never even been asked to wear a helmet at our track. But most tracks require you to wear a helmet once you get down in the 13s in the 1/4 mile. Roll bars are usually required for cars running much faster than a stock Camaro SS. At our 1/4 mile track, I believe you have to run faster than 11.20 or something like that before you have to install a roll bar. |
Thanks SGOS252382 (why did you pick that name?). The locator will help and I will plan a summer trip with my buddy who has a corvette.
![]() Drives: 1969 Pontiac Firebid Join Date: Aug 2009
Below 11.5 is when you need a rollbar. Per NHRA rules.
Free HP Tuners Beginners Tuning Guide
Michigan Snowmobiler 1969 Firebird: 7.55@97.93 1/8 1.70 60 ft.[/COLOR] EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me |
#6 | ||
SST...
Drives: SST Camaro 2010 Join Date: Oct 2008
NHRA rules require you to have a helmet if you run 13.99 or quicker. (Non-member tracks can make their own rules.) Since it sounds like your car is probably stock and you just want to go have some fun don't worry about rollbars or driveshaft safety loops until you break the 11.5 barrier. Now go have some fun !!
#7 |
Yes - it will be stock. I think it will be great fun to try 1/4 mile in my new SS - when it gets here. This fine March weather is making the wait even longer.
Thanks.
#8 | |
SST...
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Join Date: Jul 2009
There's also Lebanon Valley in New York...
I'll be at New England Dragway.... it's less than 20 minutes from my house. |
#10 |
I looked at Lebanon Valley web site. I have a lot to learn....
| Official 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 3656 | 11-01-2025 02:41 PM |
| Pedders Suspension Benchmark Track Testing and New Jersey Track Day | Info@PeddersUSA.com | USA - NY / NJ / PA | 35 | 10-26-2009 06:20 PM |
| 0-60 and 1/4 mile times (fastest production cars) | patriotpa | 5th Gen Camaro SS LS LT General Discussions | 17 | 05-09-2009 08:29 AM |
| Official 0-60 and 1/4 mile times for the SS? | topgun1 | 5th Gen Camaro SS LS LT General Discussions | 4 | 04-30-2009 12:42 AM |
| 0-60 and 1/4 mile times. | shank0668 | General Automotive + Other Cars Discussion | 28 | 07-19-2008 09:54 PM |
