Old 03-23-2010, 12:52 AM   #1
dreeve
dreeve's Avatar
Drives: 1993 lt1 z28
wheels dont fit???
i bought stock 5 spoke wheels for my 93 z28, and they dont fit...if im not mistaken the bolt pattern for all 4th gens are the same. any suggestions???
1993 lt1 z28,BBK 52mm throttle body,accel 30lb injectors,edelbrock intake,port/polished heads,1.6 rockers,erson 222in/226ex .480 lift cam,Dougs shorty headers,pcmforless chip,RK Sport competition intake , monster transmission, 3.73's, bmr suspension
[IMG][/IMG]
dreeve is offline   Reply With Quote
Old 03-23-2010, 07:48 AM   #2
02 WS6 TA
Drives: GM Stuff
'Cause those are Grand Prix Wheels...They are 5X115 MM. Incidentally, the center bore on the '98-02 cars is roughly 1mm smaller than the '93-'97, so if you wind up with a set of those, a bit of enlarging will be required to make them work as well.
02 WS6 TA is offline   Reply With Quote
Old 03-23-2010, 08:01 AM   #3
good eye
Old 03-23-2010, 05:55 PM   #4
dreeve
dreeve's Avatar
wow alright...i guess the smallest difference counts haha, but thanks you saved me alot of headaches
[IMG][/IMG]
Old 03-23-2010, 06:14 PM   #5
ron10
Drives: 2010 2SS IOM L99
Old 03-24-2010, 06:02 AM   #6
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
TA already has ya covered... Def not Camaro wheels
Old 03-25-2010, 07:12 PM   #7
Bulldogwinters
SS #2431
Bulldogwinters's Avatar
Drives: 2001 Pewter Camaro SS
Quick question on this subject, would rims off of an 02 'Maro fit on my 94? I'm lookin at some OEM rims off of the 35th Anniversary LE
Bulldogwinters is offline   Reply With Quote
Old 03-25-2010, 07:22 PM   #8
fbodyrs96
fbodyrs96's Avatar
Drives: 1996 Camaro RS convertible
yes, but you need to grind down the inside of the wheel so it fit over the rear hub.
WHY WON'T MY NEW WHEELS FIT OVER THE REAR HUBS ON MY 4TH GEN?
The 1993 to "late" 1996 4th Gen F-Bodies have a larger hub on the rear axle than on the front spindles. The rear axle hubs are about 0.03" larger in diameter than the front hubs. This problem was corrected in late 1996 model year or possibly in early 1997.
As a result, if you buy C4 or C5 wheels, or if you buy 1997 or newer F-Body wheels, they may not fit on the rear hubs of your 1993-1996 F-Body.
The solution is very simple. First, DO NOT FORCE THEM ON WITH THE LUGS! Very dangerous, and you may not be able to get them off. You need to lightly sand or grind (e.g. - Dremel) the inside diameter of the hub hole in the back of the wheel. Don't go nuts.... just remove enough metal so the wheel cleanly fits over the rear hubs, with no interference.
Think about doing this to all 4 wheels, so you can "rotate" the tires in the future.
This will not harm the wheels.... you are taking off the thickness of a sheet of paper. Just be sure you do a neat, smooth job. This will also NOT affect the centering of the wheels on the hubs. The 4th Gen wheels are "lug-centric" - they are centered by the conical lugs, not by the hubs.
fbodyrs96 is offline   Reply With Quote
Old 03-29-2010, 10:04 PM   #9
ninety6
2xSOM
ninety6's Avatar
Drives: 2002 Camaro SS | 2002 Camaro V6 vrt
yup. i got the Chrome 5-stars from a 98 Z28 and stuck em on my 96 to replace the salad shooters... had to take a dremel around the center to get them slide on. wasn't too bad though...
ninety6 is offline   Reply With Quote
Old 03-30-2010, 08:10 PM   #10
White_Knuckle_Tight
Drives: 2001 Camaro V6
ok, weird question here. I have an 01, and I ran into the 93 - 96 problem when i rotated my wheels, so wtf? It was exactly as you guys described, the front wheels wouldn't go on the back, I had to grind them out. So what's going on?
White_Knuckle_Tight is offline   Reply With Quote
Old 03-30-2010, 08:13 PM   #11
lee
lee's Avatar
Drives: 2010 2ss/rs
i dremeled a set of 10 spoke ss's on a lt1 as well , easy fix
lee is offline   Reply With Quote
Old 03-30-2010, 08:14 PM   #12
Ant32894
Youjellybra?
Ant32894's Avatar
Drives: 95 3.4l V6
Someone did something to the car before you got it. Mine fit on all 4 sides!
Animated Gif not allowed
Ant32894 is offline   Reply With Quote
Old 03-31-2010, 01:33 AM   #13
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
if they are stock wheels, they more than likely will not fit without grinding or spacers
same as above.
what happened was that GM went with a slightly smaller rear axle hub size when they came out with the 97 camaros, same as how the 97s have the LS1 style dash. it was an "in-between" period where they were trying new things on the car.
you have 3 options,
1. grind the axle hub
2. grind the wheel lip
3. run spacers
I piss excellence
and fart awesomeness
Old 03-31-2010, 08:16 AM   #14
fbodyrs96
fbodyrs96's Avatar
X2
2010 Camaro wheels 10.75 " wide rear ADM PERFORMANCE Wheels / Tires 56 10-17-2012 10:00 PM
possible to fit old style rally wheels on new camaro? RSPARKS5 Wheels and Tires Talk Sponsored by The Tire Rack 17 07-18-2011 12:09 PM
Autoblog drives V6 Camaro w/ ground effects and GMPP wheels. Shares public reaction. Tran 5th Gen Camaro SS LS LT General Discussions 1 07-13-2009 12:17 PM
