Old 03-27-2010, 02:35 PM   #1
jrcase
Drives: 2010 Black/Black 2SS
Changed the differential fluid today, but.....
I bought 1 Qt. of Royal Purple. I set the car on 4 jack stands and got it as level as I could. I opened the top fill hole bolt and expected fluid to come out but none did. Anyway, I opened the bottom hold and let it drain for about 1/2 hour. (Nasty stuff, full of metal shavings). Came back and filled the differential with the whole quart but it never did overflow back out (I expected to be able to know when it was full by it coming out the top hole). I did get 99% of the quart bottle in there. Since it didnt start to overflow out of the top hole, am I a little low on oil now? I wouldnt think so since none came out when I first opened it. I test drove it and all was normal.
Did anyone else use a full quart and still not have any overflow? Please advise. Thanks!
jrcase is offline   Reply With Quote
Old 03-27-2010, 02:40 PM   #2
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
Check your manual for quantity! It should be filled till it overflows. Stop driving till you do that!
Fishdadddy is offline   Reply With Quote
Old 03-27-2010, 02:57 PM   #3
obe1
obe1's Avatar
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28
Capacity is one quart; you're fine!
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected - Sold
1968 Camaro - Sold
2019 Corvette Grand Sport
obe1 is offline   Reply With Quote
Old 03-27-2010, 04:25 PM   #4
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
Capacity is 1.055 qts. So you may be a little short. You should fill it until it comes out the fill hole.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 03-29-2010, 12:59 PM   #5
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Stick you're little finger in the fill hole and bend it down. If the oil is just below the threads, you're OK. If its more that 1/8 inch down, add some more.
Old 03-30-2010, 09:09 AM   #6
jrcase
For peace of mind, I went and bought another quart of Royal Purple and filled it until it came back out. I was surprised at how much more it took. Anyway, I am good now. Thanks for the advise.
Old 04-01-2010, 11:40 AM   #7
ninety6
2xSOM
ninety6's Avatar
Drives: 2002 Camaro SS | 2002 Camaro V6 vrt
same thing happened to me on my fill. I had like a couple drops (literally) come out the top hole when draining. My car wasn't exactly level (pointed down a hair, but pretty close.
I stuck my pinky in the top hole and i could feel the oil JUST below the threads, so it was perfect.
ninety6 is offline   Reply With Quote
Old 04-01-2010, 12:15 PM   #8
Mr Smith
Born again Hot Rodder
Mr Smith's Avatar
Drives: Black 1SS/RS LS3 M6
Whats the Royal Purple part number or description? Also, is it listed under the GM approved for use list?
Mr Smith is offline   Reply With Quote
Old 04-04-2010, 12:02 PM   #9
Merc
In The Circle
Merc's Avatar
What! No GM additive. They say additive first then the litre of Diff fluid and it should be all good.
Old 04-04-2010, 12:03 PM   #10
flyby
Drives: 2010 Silver SS
I hope you used the additives also.
flyby is offline   Reply With Quote
Old 04-04-2010, 12:20 PM   #11
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
You don't need any additive with the Royal Purple, it's already in there.
FrankT is offline   Reply With Quote
Old 04-12-2010, 11:56 AM   #12
devildoc
devildoc's Avatar
Drives: '12 Toyota Tacoma Dbl
It should already have the LS additive in it. The transmission fluid is the only one you have to be careful with.
STANDING 1/4MI: 13.948@99.87
6600RPM HP/TQ Gains - 30.54HP/24.3TQ (NOT PEAK)
devildoc is offline   Reply With Quote
Old 04-12-2010, 07:00 PM   #13
DarricSS
DarricSS's Avatar
Drives: '10 Camaro SS
Royal Purple and Redline don't need the friction Modifier...
Mobile1 GL-5 75W90 requires Friction Modifier GM Part No 1052358 2.5 oz.
2010, SIM, 2SS/RS, LS3, CGM Stripes
DarricSS is offline   Reply With Quote
Old 04-12-2010, 07:03 PM   #14
Reeko
Drives: 69 Camaro RS Conv. 2010 Camaro SS
The only Mobil 1 I see on there website does not require additives.
http://www.mobiloil.com/USA-English/..._75W-90LS.aspx
Reeko is offline   Reply With Quote
Can't Decide - Auto or Manual attymf Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 213 02-22-2022 08:48 PM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Changed the Diff and M6 trans fluid today... FirstLSK Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 28 04-15-2010 09:21 AM
V6 M6 & A6 Differential and Transmission Fluids - Recommendations... V6 ONLY PLEASE! ninety6 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 2 04-14-2010 08:28 AM
Changed my interior today shane@davesmith Camaro Price | Ordering | Tracking | Dealers Discussions 22 11-05-2008 08:54 PM
