Old 04-03-2010, 07:22 PM   #1
elcamino85
elcamino85's Avatar
Drives: 1985 chevy el camino
Fuel additives?
So I was wondering if anyone adds anything to their fuel. Like a fuel system cleaner or that octane boost stuff (never used that). I have always used the fuel system cleaners on all my cars and it really helps out when I begin to notice a drop in gas mileage.
elcamino85 is offline   Reply With Quote
Old 04-03-2010, 07:28 PM   #2
tjmac49
Drives: 2010 Camaro SS/RS, IBM, L99
tjmac49 is offline   Reply With Quote
Old 04-03-2010, 08:21 PM   #3
nosrettap58
nosrettap58
nosrettap58's Avatar
Drives: 2023 Camaro 2SS Convertible
Here in montana our max octane is 91. The higher the elevation, the less octane needed. Wonder how that effects the computer settings?
nosrettap58 is offline   Reply With Quote
Old 04-03-2010, 08:22 PM   #4
Soundwave
Soundwave's Avatar
Drives: Camaro SS(2)/RS
If you google this topic you'll find a lot of discussion about how none of them do anything at all. The octane rating you gain is VERY MINIMAL.
What DOES work is mixing your fuel. I was getting the 101 octane (unleaded) and filling 1/4 tank with it, and 91 (the highest we have here) for the rest. The 101 is $7 a gallon so for 1/4 tank I'm paying about $25 but I'm actually raising my octane level instead of just throwing my money away with the gimmick octane boosters.
Soundwave is offline   Reply With Quote
Old 04-03-2010, 08:24 PM   #5
elcamino85
elcamino85's Avatar
What about fuel cleaners since those actually work for me.
Old 04-03-2010, 08:30 PM   #6
Soundwave
Soundwave's Avatar
I'm sure a fuel cleaner wouldn't hurt. I haven't researched that enough to really tell you though. I wouldn't expect amazing results still. Higher octane rating doesn't equal faster car necessarily. Keep that in mind.
Old 04-03-2010, 08:31 PM   #7
elcamino85
elcamino85's Avatar
Thanks for the info
Old 04-03-2010, 08:31 PM   #8
Lbness
Drives: 2010 ss M6 Aqua Blue
Send a message via AIM to Lbness
Techron every 20 tanks or so ... does clean fuel systems
Lbness is offline   Reply With Quote
Old 04-03-2010, 08:33 PM   #9
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
You ever looked on the back and read what was in it? Most of the stuff you can buy in the store is almost nothing but ethanol and rubbing alcohol, both of which is terrible for gasoline engines, and it takes more then just the 1 tank most people use for it to work. The octane booster only increase the octane level by .5-1 point in a 20 gallon tank, such a huge ripoff.
Use the highest grade octane for your area (either 93 or 91) and you'll notice better results then any of these off the shelf additives will give. Mix in a gallon or two of racing gas like mentioned above and you're see a lot more gain for your money.
Old 04-03-2010, 08:35 PM   #10
elcamino85
elcamino85's Avatar
Like I said I have never used the octane stuff before I just always see it next to the fuel cleaner which I use regularly like the other post said 20 fill ups or so sometime 10.
Old 04-03-2010, 08:40 PM   #11
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Better off buying a $1 bottle of rubbing alcohol and putting in half of it imo. You'll get the same results as that's mostly what it is made of.
Old 04-04-2010, 06:07 PM   #12
RCLapCar
RCLapCar's Avatar
Drives: 2016 2SS A8 HB/JB
Looks like my local Petro Canada stations are going to start selling 94 octange gas No need for additives I guess.
Current: 2016 2SS Hyper Blue/Jet Black
Former: 2010 2LT/RS IOM/IO - Solo Catback w/ J-Pipes
RCLapCar is offline   Reply With Quote
Old 04-04-2010, 10:39 PM   #13
joe h
Drives: victory red 2010 camaro 2ss/rs
No gas station in North Dakota offers 93 octane, despite the elevation in the state ranging from just less than a thousand feet out east and about 1500 to 2000 for the central. So I have been mixing 10% e85 with 91 octane. If I done the math right it should give you about 92.1 to 92.5 octane. Of course depending on the ethanol content in the 91 octane I could be putting up to 16% ethanol in the tank. Tried looking for unleaded racing gas in the Bismarck area, but no one had any.
Just my opinion, but it would be nice if gm would have their higher compression cars as flex fuel, since these cars can take advantage of the higher octane.
joe h is offline   Reply With Quote
Anybody Spray'n their SS yet - nitrous ? WeeZee Forced Induction - V8 37 12-29-2012 10:56 PM
Stock Injectors vs Magnuson Kit Injectors Mark-HD Forced Induction - V8 24 01-27-2010 09:04 PM
Why i think you cant do a Dyno in the same day 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 123 10-22-2009 08:37 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
