BAMF SS
Torque management question
I have a dumb question about how the torque management works on these cars. This is my first car with torque management on it, as well as traction control (mine is a manual btw)
How exactly does it limit the power output? I went to the track today and when I did a burn out, I get two wheels spinning. When I launched and if I spun, only one wheel would spin. I'm hoping my posi isn't already going out on it. I messed with the tune a little bit.... it still has SOME torque management in it... didn't know if I should just max it out or what were most people doing with it on the manuals.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
I used to be Dragoneye...
As I understand it, the computer will feather the throttle within a range of the accelerator pedal position in order to reduce engine power output. Fuel and timing may also be retarded, though I'm not sure.
BAMF SS
shit... so my posi is on borrowed time? or is there something else that might be causing this?
I held the t/c button down for 7 seconds and had both traction control and stabilitrak off
CamaroFans.com
There is no TCM... on an LS3...
Not sure how you would adjust TMI think you might be speaking of Traction Control.... |
BAMF SS
there were values in it on hp tuners?
#6 |
I'm curious about the conditions...how did you know one spun and the other didn't? Was there dirt/grass or pavement...and did you spin them for a long time, or just a quick blip?
#7 |
BAMF SS
friend of mine told me, as he watched me launch. he heard spinning, he heard the engine revving.... but only one wheel was doing it. and just for a quick moment on the initial launch
#8 | |
Unless someone with greater tech knowledge in here can pitch in with a better explanation/solution.
#9 | |
BAMF SS
and ummmm take a look at my signature and tell me again i should take it to the dealer for warranty work? lol
#10 | |
![]() In that case...if they don't ever lock up, replace it. hehe. The differential is not a race unit, and the difference in wheelspin before lockup is probably "high", resulting in one-sided spin under quick blips.
#11 |
Drives: 2006 Corvette Z06 Join Date: Feb 2010
Torque management pulls timing and backs off the throttle sometimes, even on manual cars (to address mlee). It's to prevent part failure from shock.
Anyway, torque management has nothing to do with only one tire spinning. If it was a quick instance where only one spun, then I wouldn't worry. If it was a rolling condition where one spun and the other stayed still, then I'd be concerned. |
#12 | |
CamaroFans.com
#13 |
Maybe one tire just had less traction than the other, resulting in slippage of that wheel only until the rear locked.
#14 | |
![]() Drives: 1999 500 HP Corvette Join Date: Jan 2010
The PCM becomes a dyno in that it can calculate what the torque is under all conditions. It uses several feedback sensors such as the MAF, MAP, throttle angle, YAW sensor and wheel sensors. As shown here you can see the PCM can control these functions by control of throttle, fuel injectors, and timing. These functions can be properly adjusted with a good tune, watch out for the lazy tuners that just turn the functions off as the sensors see what you cannot and also react faster so at times TM can reduce wheel spin and have better drag strip ETs. Best is to tune TM that best suits your drive style It also is important that you do not allow a tuner to just screw around with the MAF tables for the wrong reasons as this will then effect what the air mass / engine load is and cause the PCM to calculate the torque incorrectly. TM will effect how much timing the PCM commands and can effect the torque converter if automatic trannie is used. This is just part of the values and tables in the PCM that we tune as per the car's makeup, how the owner tends to drive and what mods they have added.
| Need knowledgable opinion | firengnred | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 12 | 02-27-2010 09:23 AM |
| Question about back pressure and torque | firengnred | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 02-18-2010 12:42 PM |
| Question Involving 4.10 gears & Bushings | Deric884 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 1 | 02-13-2010 07:53 AM |
| Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 06:29 PM |
| 5th Gen Camaro LS3 info from Chevy Hi-Po...READ | TAG UR IT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 295 | 03-07-2008 11:06 AM |
