Old 04-03-2010, 09:46 PM   #1
flyby
Drives: 2010 Silver SS
Bleeding Brakes
Does anyone know if there are any special tools or anything needed to bleed the brakes on one of these 2010 ss"s???
flyby is offline   Reply With Quote
Old 04-11-2010, 04:19 PM   #2
RefrigerationGuy
Drives: 09Sierra10Suburban 2SSRSbk/io
I removed my brake calipers to paint them orange. when i reinstalled them I just bled them the same as my old 77 chevelle in High School. Loosen bleed port with a 10mm or 11mm box end wrench and have someone help you press on the brake until no more air in the lines. make sure you keep system full while you bleed so you don't get more air in the lines. use dot3 brake fluid I think?? check the cap.
RefrigerationGuy is offline   Reply With Quote
Old 05-03-2010, 06:55 PM   #3
dragon22
Drives: 2010 Camaro 2SS/RS SIM
You can also do what is called "gravity bleed".
Make sure you keep the master cylinder full at all times. If it goes dry, then you have to bleed right from the master cylinder. And that can be a pain!
With the master cylinder full and all the bleeders open, just let gravity do it's job. You will actually see air bubbles coming out of the bleed screws when you the fluid starts coming out. Be patient...gravity works wonders. If you don't see fluid coming out, wait. I assure you it will start coming out.
Disadvantage? If you have paint on your calipers, the brake fluid will eat the paint off as it rolls over them.
You also used to be able to get "self bleeding kits" from parts stores. It was a kit that had a hose, or hoses, you could "clamp" onto the bleeder, then run it away from the caliper, or submerge it into a container of brake fluid and slowly work the pedal yourself. I prefer the gravity bleed method, then get a friend to help you with a quick bleed at each wheel to make doubly sure all the air is out.
If you're going to bleed them the conventional way, start with the wheel farthest away from the master cylinder and work your way to the one closest to the master cylinder.
Hope this helps!
dragon22 is offline   Reply With Quote
Old 05-03-2010, 09:19 PM   #4
foxxone
foxxone's Avatar
Drives: 2010 2SS/RS IBM
If you are looking for a specialty tool , try this: http://www.brakebleeder.com/index.ph...products_id=14.
It pushes the air out the master cylinder instead of out the bleed port onto your freshly painted calipers. However, if you are not going to be doing this all the time, you can save your $169.99 and listen to the above posts.
Good luck!
foxxone is offline   Reply With Quote
Old 05-03-2010, 10:09 PM   #5
dragon22
I like the looks of that!
Old 05-29-2010, 05:37 PM   #6
Dentyneice
Drives: 2010 Camaro 2ss
Will that bleeder be a sure fit for the Camaro? I was planning on buying one for when I get a line lock kit
2010 CGM/Black 2SS M6
20% Tint -:- Hurst 44% Short Throw Shifter -:- Viper 5901 Alarm/Remote start -:- High Gloss Black Painted Calipers + White Brembo Decal
Dentyneice is offline   Reply With Quote
Old 05-29-2010, 05:50 PM   #7
HaZe_X
HaZe_X's Avatar
Drives: Trailblazer SS & Camaro SS
Do the brembos have 1 bleed port per caliper, or 2?
2010 Camaro 2SS/RS/LS3 -Black on Black - Kooks 1-7/8 Headers, Dyno Tuned, ADM Race CAI, QTP Cutouts, Hurst Short Throw, SJM Line Lock, Alpine PDX 1.1000, (2) Alpine Type R's, ...Soon to be cammed!
HaZe_X is offline   Reply With Quote
Old 05-29-2010, 11:12 PM   #8
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
2 bleeders per cailper!!!
Gotthat02fire is offline   Reply With Quote
Old 05-30-2010, 03:06 PM   #9
Dentyneice
Do you have to bleed both at the same time? Alternate? Or just chose one to bleed? I was thinking on getting the V-12 bleeder from the link above http://www.brakebleeder.com/index.ph...products_id=14
Old 05-31-2010, 03:20 AM   #10
dragon22
If you're going to bleed the brakes with a friend, I would gravity bleed them first. (As in a previous post.) Be certain the master cylinder does NOT go dry. Keep it full of fluid. Another tip...when you're gravity bleeding, you will have to leave the lid off the master cylinder.
When the fluid seems to be flowing out of the calipers without any signs of air, close all the bleeders and make sure the master cylinder is full. Put the lid back on the master.
Starting with the R/R wheel (passenger rear) crack the bleeder and have your friend push the brake down slowly and smoothly. Before the fluid stops coming out of the "bleeder screw", tighten it. Do this at least twice. More if there is any signs of air coming out of the screw with the fluid. You have to be sure your friend does not lift his foot off the pedal before you close the screw.
Move to the L/R (driver rear) wheel and repeat. Then to the R/F (passenger front) wheel and repeat. Then the L/F (driver front) wheel will be the last one you will need to do. During all this, do not let the master cylinder go dry.
Also be sure you do not get brake fluid on the paint because if it sits on the paint too long, you will need to repaint. It will eat the paint off the car or any painted surface.
If you're really uncertain about doing this and you have someone you know with good automotive experience, as him/her to come over and give you a hand.
Hope this helps! :-)
Old 05-31-2010, 04:26 AM   #11
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
+1 for gravity bleed, seems to work the best over the forced fluid methods for me.
Though in a pinch speed bleeders are nice but I never leave them installed.
Had one leak before. it BLOWS
Put some fish tank hose over the nipple to gravity, no lost paint.
2013 5th Gen Firebird on order.
86 Pontiac Firebird [a work in progress]
[68 Firebird hoodscoops, custom notchback[1-3 built]rear mounted tach, inverted wing]
http://www.thirdgen.org/techboard/v6...-all-over.html
"In certain extreme situations, the law is inadequate.
In order to shame its inadequacy, it is necessary to act outside the law.
To pursue... natural justice.
This is not vengeance.
Revenge is not a valid motive, it's an emotional response.
No, not vengeance.
Punishment."
2ndgenz28 is offline   Reply With Quote
Old 05-31-2010, 08:59 AM   #12
Dentyneice
Do the 2SS model's have hydraulic clutches? I think this is a pretty good demonstration on how to use the V-12 DIY kit.
Old 05-31-2010, 01:53 PM   #13
HaZe_X
HaZe_X's Avatar
Perfect explanation! But heres my question, since the brembos have two bleeder per caliper, how does that work? Do we just choose one? Open both at the same time? Little confused on that part..Thanks
Old 05-31-2010, 02:11 PM   #14
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
Star with the inner first, then the outer on each caliper as you go around the car. just did mine last week. Worked out great 1st shot. I have a thread going around about my powdercoated calipers. Check it out.
Fishdadddy is offline   Reply With Quote
ZL1 / CTS-V Brakes JusticePete Suspension / Brakes / Chassis 584 10-14-2021 10:33 AM
Drum brakes hard to beat KILLER74Z28 General Automotive + Other Cars Discussion 17 02-16-2012 01:40 PM
Bleeding Brakes flyby Suspension / Brakes / Chassis 9 04-06-2010 10:26 PM
Bleeding Brakes flyby Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 0 04-03-2010 08:40 AM
EWB Electronic Wedge Brakes KILLER74Z28 General Automotive + Other Cars Discussion 10 11-13-2006 01:12 AM
