Old 04-07-2010, 10:25 AM   #1
strauchpete
Drives: 2010 Camaro 1LT
Question v6 and v8 suspension difference?
I was wondering if there was a difference between the suspension of a v6 and v8 2010 camaro.
I have been looking around coil overs, sway bars, trailing arms, ect and most of them dont say if they are for v6 or v8.
strauchpete is offline   Reply With Quote
Old 04-07-2010, 01:47 PM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Most of them are for the V8. I know Eibach makes a V6 set. They're sitting two feet away on the floor waiting to get put on Friday Now, whether or not a V8 set could be used on a V6, I'm not sure. I would think the weight and balance would be difference so the sets for the 6 and 8 would be engineered differently, but really that's a guess.
Old 04-07-2010, 02:40 PM   #3
strauchpete
I also read that v6 guys are putting v8 sway bars in there cars and they are helping and a cheap upgrade. That the v8 sway bars are bigger and stiffer then the V6 ones.
Old 04-07-2010, 04:10 PM   #4
jputer
jputer's Avatar
Drives: 2016 1LT Garnet Red
The bars and shocks are different between the V6 and V8, but all the brackets, bushings(?) and end links are the same.
from Super Chevy Magazine:
http://www.superchevy.com/features/c...ecs/index.html
Two suspension packages are offered: FE2 sport on V-6 models and FE3 performance with the V-8. The front suspension has a dual ball strut system, with a direct-acting stabilizer bar that measures 22.2 x 4 mm on FE2 and 23 x 4.2 mm on FE3. Hollow bars are used for mass savings. The front spring rates for FE2 models are 25 Nm, with wheel travel at 96 mm. FE3 models include a stiffer, 27 Nm spring rate, with wheel travel reduced at 84 mm.
Rear suspension features include high lateral stiffness for handling via three lateral ball joints per side. A sub-frame at the rear is double-isolated to minimize vehicle body motions and dampen road imperfections. The FE2 with a manual transmission includes a spring rate of 53 Nm, with wheel travel at 115 mm, and employs a limited-slip differential. The FE3 rear axle uses a limited slip differential on both manual- and automatic-equipped models; and the rear spring rate is increased to 66 Nm and wheel travel is reduced to 100 mm. Coil-over shock absorbers are used in the rear with a decoupled, hollow stabilizer bar. FE2 includes a 21.7 x 3 mm rear bar, while the FE3's large bar measures 23 x 3 mm.
2011 1LT/RS Summit White A6
jputer is offline   Reply With Quote
Old 04-07-2010, 05:44 PM   #5
xtreme industries
Drives: 2010 Camaro 2lt RS
you can uses V8 springs and sways in a V6, some members here have already done it with no issues.
i went with the eibach V6 kit for my LT2, made a world of difference. the only thing i didnt like about the camaro when i bought it was the handling, now i am happy with it.
xtreme industries is offline   Reply With Quote
Old 04-07-2010, 09:38 PM   #6
strauchpete
Ya I live in missouri... the longest strait stretch of road would be a bridge, is its alot of fun to drive but I do notice that it does have alot of body roll.
Old 04-08-2010, 04:50 PM   #7
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Hi strauchpete,
The info that you have read above, is correct to the best of our knowledge. The rates of anti-roll bars and springs are very close to each other, all things considered. Weight of the V8 and V6 models are also very close. Because of this, in reality the performance targets of customers with both V6 and V8 models, are for the most part, the same. Because of this, most companies (like ourselves) are not discrete as to which model our parts are made for. Sure, we like to provide products for the highest performing model, but that is not to say suspension parts engineered using a V8 model for reference, will not work well on your V6.
All of our V6 customers have great things to say about our products, as they still have the same performance targets as our V8 customers. Let me know if you have any questions about our parts for V6 or V8 Camaros! Thanks for your time.
Old 04-08-2010, 05:11 PM   #8
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
I have been looking around coil overs, sway bars, trailing arms, ect and most of them don't say if they are for v6 or v8.
Last year we went to the *Martinrea Plant* near Oshawa were they make the suspensions for the Camaro and the only piece that is different on the SS is this bar..see pic ..That's what we were told by the plant Manager....
If I 'm not mistaken...
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty
CAI - Cold Air Inductions / VMAX TB / Trifecta Tune
Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can
ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit
ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports
ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller
Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels /
Oracle Afterburners / Oracle Concept SMD Side markers
Complete SS Brembo Brakes Set
RickRay is offline   Reply With Quote
Old 04-08-2010, 08:12 PM   #9
CamaroDreams07
Drives: Slow V6
I'm getting the V6 Eibach kit put on in the morning. I'll let you know how it feels after. I went with Eibach because it was the one that was in my price range, and it was the only one I found that was specifically for the six. Eventually I want to step up to full coilovers, but this is an intermediate means to an end for me until I get that kinda money.
Old 04-09-2010, 07:03 AM   #10
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
Im certain that was a neat experience.
On a side note, those trailing arms need replaced any how for anyone wanting to make moderate power, or attain better grip
-Regards
IPS Brandon is offline   Reply With Quote
Old 04-14-2010, 10:14 PM   #11
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
We have found there has been little difference between the V6 and V8 suspension. In fact, a stock V6 will out brake and have a .2g higher skid pad rating than the SS.
With that said, Pedders decided it was not necessary making a different set of products for the V6 models. Just be thankful that with equal wheels and tires, and appropriate upgrades, you will be able to get your V6 Camaro to handle with the best of Camaros.
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 04-24-2010, 06:41 PM   #12
EfiniRX7
Drives: 2010 2lt camaro RS
I did not see if the ride height was addressed. Is the ride hight any different between the v8 and v6? I have a great deal on new stock ss shocks, both sways, and the springs. I have a 2lt rs and it just sits to high. It might just be me but the ss seems to sit lower. I heard some where that the ss sits 1in lower than the v6, but who knows if thats accurate.
EfiniRX7 is offline   Reply With Quote
Old 04-27-2010, 04:15 PM   #13
macwest
Drives: 10 Camaro 2SS/RS, 70 Cuda, 71 Cuda
Eiback v8 springs give you just under a 2" drop on a V6. The V6 sits 40mm higher then the V8. On my Lt1/RS I lowered it with Eibach V8 springs and was very happy.
macwest is offline   Reply With Quote
Old 04-27-2010, 04:41 PM   #14
ScottyB911
ScottyB911's Avatar
Drives: 2016 2SS Coupe
I did the Eibach V6 springs and sway bars (29mm front and rear) The wheel wells are filled perfectly (for my taste) the ride is still comfortable at cruise and yet I can do an off ramp at over 40mph and the car is flat and sure footed.
ScottyB911 is offline   Reply With Quote
Help me make a decision about a camaro v6 or v8 thejoker1232 General Automotive + Other Cars Discussion 15 07-30-2010 12:38 PM
Richmond Gears V8 and V6 - Group Buy ZZcamaro Transmission / Driveline 175 04-30-2010 12:29 AM
Who has driven the V6 and the V8? Need your thoughts sask-man 5th Gen Camaro SS LS LT General Discussions 52 02-19-2010 10:06 PM
difference between v6 and v8 models 00kar 5th Gen Camaro SS LS LT General Discussions 7 01-13-2010 05:21 PM
V8 appearance vs. V6 Discussion! jpsuperman81 5th Gen Camaro SS LS LT General Discussions 19 08-08-2009 09:01 AM
