Old 04-09-2010, 08:37 PM   #1
cajun2010
cajun2010's Avatar
Drives: 2010 1LT/RS
factory v8 springs on a v6???
Ive seen some v8s in person and they look lower than the v6.
Do the 2 models use the same springs, and if not, has anybody put the stock v8 springs on the v6? will it lower a v6 to the v8 height?
cajun2010 is offline   Reply With Quote
Old 04-11-2010, 01:53 PM   #2
cajun2010
cajun2010's Avatar
Drives: 2010 1LT/RS
so i take it as nobody has tried the V8 springs on a V6??
Old 04-11-2010, 02:04 PM   #3
mdinferno
mdinferno's Avatar
Drives: 2010 IBM 2LT/RS
I measured my buddy SS and it the same height at my 2LT RS.
mdinferno is offline   Reply With Quote
Old 04-12-2010, 11:28 PM   #4
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
I was told there are only 2 sets of coils for the entire Camaro line. With that said, you can have as much as a 1/2 inch difference in heiights from one SS to another.
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 07-19-2011, 06:17 AM   #5
gwbates3
Ruby & Blu Imp
gwbates3's Avatar
Drives: 2010 LS3 2SSRS M6 & LLT RS A6
http://www.camaro5.com/forums/showth...=v8+springs+v6
see post #21
Ruby
2SSRS M6 - Blown & LLT RS A6
gwbates3 is offline   Reply With Quote
Old 07-19-2011, 06:20 AM   #6
IROCanSS
Drives: 89 IROC 350
I did the swap on a buddies LT. It makes a slight difference. I suggest if you're going through the hassle, spend $250 on some drop springs.
JBA Performance Headers | Mid-Pipes | Exhausts | V6/V8 | FREE S&H!!! AJ@ECSMotorsports V8 Bolt-Ons & Tunes 100 11-13-2010 03:51 PM
Who has driven the V6 and the V8? Need your thoughts sask-man 5th Gen Camaro SS LS LT General Discussions 52 02-19-2010 10:06 PM
Camaro v6 or Trans am v8 iyam_lorne 5th Gen Camaro SS LS LT General Discussions 5 01-26-2010 05:59 AM
Lowering Springs on the V6 marley. Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 15 01-07-2010 04:42 PM
should i get a v6 or a v8 thejoker1232 General Automotive + Other Cars Discussion 7 10-02-2009 09:20 AM
