Old 04-11-2010, 06:26 PM   #1
cybercoaster
cybercoaster's Avatar
Drives: 2017 2SS 50th Anv, 1972 RS
Am I missing any parts to put this exhaust together?
I have the L99 and will be getting a tune and rid of AFM. Are there any other parts I need to order or will all this hook right up together?
Kooks 1 7/8 long tube headers
kooks high flow cats
xpipe
and Magnaflow Street catback or Borla S type.
Thanks
cybercoaster is offline   Reply With Quote
Old 04-12-2010, 08:26 AM   #2
toehead93
Drives: 2014 2SS/1LE
You have the -xpipe listed separately but the Magnaflow and Borla catbacks come with x-pipes so no need to get another. I'm not familiar with installing Kooks but everything should bolt right into place.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 04-12-2010, 08:39 AM   #3
jhmurphy
jhmurphy's Avatar
Drives: Grey Beast
As for the Kooks make sure you get the wire extenders for the O2 sensors in the front. Depending on who you order from they should come with your headers. Also several of us have had issues removing the front O2 sensor on the passenger side. It had to be replaced it was cross threaded from the factory from what i can tell. Good luck
jhmurphy is offline   Reply With Quote
Old 04-12-2010, 04:42 PM   #4
cybercoaster
Thanks all!
Old 04-12-2010, 08:11 PM   #5
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
The Camaro Cat back systems made by anyone are designed to connect to the factory cats. Once you install LT and high flow cats, unless they end in the same spot as the factory cats you will have a problem connecting the two systems.
HeavyD is offline   Reply With Quote
Old 04-12-2010, 08:58 PM   #6
Dirtdog
Pro Hide n Seek Player
Dirtdog's Avatar
Drives: 2010 SS LS3/LSA 620whp/630tq
Send a message via AIM to Dirtdog
thats gonna be a nice setup, goodluck
620whp/630wtq. ADM LSA Conversion, E85, PFADT Tri-Y Headers into Borla S, PFADT Swaybars, Springs, Links, 20x10 20x11 Forgestar F14s, Lots of AAC
Dirtdog is offline   Reply With Quote
Old 04-13-2010, 12:24 AM   #7
jeffhatton
Drives: 2010 Camaro
Just make sure that you leave everything loose when putting together and tighten(torque) from the headers back. Things will line up much better and the process will be a much quicker one. Sounds like a great setup!
jeffhatton is offline   Reply With Quote
What song are you listening to right now Muscle Master Off-topic Discussions 6760 11-08-2025 02:54 AM
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 612 09-06-2024 09:00 AM
333 Ways to get kicked out of Walmart (just funny- do not try this at home) Abygale Off-topic Discussions 47 04-28-2010 02:20 AM
(UPDATED) Stainless Works exhaust and header systems!! (Tag's SS w/ HP #'s) Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 162 07-09-2009 07:39 AM
