Old 04-11-2010, 06:46 PM   #1
hambone3441
Drives: 2010 Camaro 2SS/M6 Rally Yellow
Dyno....thoughts???
Got my car on the dyno for a baseline. LS3 M6. Pulls where in 4th and hit the speed limiter on the pulls.
Got 340hp out of it on a dyno dynamics..... was hoping for a bit more but heard this type of dyno is typically a bit lower that a dynojet. Open to inputs.... Thanks.
hambone3441 is offline   Reply With Quote
Old 04-11-2010, 08:28 PM   #2
Sax1031
Drives: 2000 Mustang GT
If it is a dyno like a mustang dyno that actually puts a load on the car during the dyno runs then the numbers will be lower than on dynojet numbers.
Sax1031 is offline   Reply With Quote
Old 04-11-2010, 10:01 PM   #3
blueallie
blueallie's Avatar
Drives: Abm 1ss/rs 6m
Where'd you get your dyno done at? I pulled 358hp on a dyno dynamics in Manassas.
blueallie is offline   Reply With Quote
Old 04-11-2010, 10:09 PM   #4
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
It's not as important as what you get when you change something and re dyno. Some dyno's read higher or lower than others. The most important part is to try and use the same dyno when modifying in order to get the most accurate depiction of losses and gains.
9/26/09 Took delivery!
Old 04-11-2010, 10:13 PM   #5
Sax1031
Definitely a dyno is really nothing more than a tuning tool.
Old 04-11-2010, 10:23 PM   #6
2010SSRSM6
2010SSRSM6's Avatar
Do you have your sheet? What smoothing did they use? Was it SAE or STD? Those will make a difference as to what the final numbers are also.
As long as you get it dyno'd using the same settings everytime you add a part/dyno on that dyno you'll have a better idea as to the benifit of the part/parts added.
Welcome to the addiction that is Camaro.
Old 04-11-2010, 10:53 PM   #7
Sax1031
STD numbers are generally lower than SAE numbers. Unless the STD numbers were from some crazy -2000 DA or something to that effect.
Old 04-12-2010, 03:42 AM   #8
THE EVIL TW1N
Banned
Drives: 2003 Cobra Convertible
actually, STD numbers are generally ~2.5% higher than SAE.
THE EVIL TW1N is offline   Reply With Quote
Old 04-12-2010, 03:46 AM   #9
Camaro_hx
Drives: 2010 1LT/RS CGM
Send a message via MSN to Camaro_hx
sounds good, similar hp to most my SS friends run on Dyno
Camaro_hx is offline   Reply With Quote
Old 04-12-2010, 05:48 AM   #10
hambone3441
I got it done at Function Tuned in Sterling, va.....right outside of dulles airport.
I have the graph and will try to scan it in later today. Thanks to all on your inputs.
Old 04-13-2010, 02:53 PM   #11
SS Matt
SS Matt's Avatar
Drives: 2010 2SS/RS, LS3, M6, CGM
I got my LS3 done on a Dynojet using STD: 1.02 and my results were 380.81 hp / 387.50 tq. Given what most other LS3s are getting, I'm right in line with them considering the STD setting and the dyno.
SS Matt is offline   Reply With Quote
Old 04-16-2010, 03:52 PM   #12
hambone3441
finally got the dyno graph up..... Let me know what you think.
Old 04-16-2010, 07:34 PM   #13
4xchamp
MURC 666
4xchamp's Avatar
Drives: 69 Pace Car 68 Camaro Restomod 81 Z
Here's mine on a Dynapack dyno with open air intake .
The #'s mean nothing these cars all make within a few horsepower of each other .
The air intake picked it up about 15 hp .
Guys hoarding their Camaros are depriving some youngster the opportunity to restore it 25 years from now .
Drive it like you stole it , let the next guy baby it !
4xchamp is offline   Reply With Quote
Old 04-17-2010, 04:44 PM   #14
hambone3441
Any more feedback on the baseline dyno?
Roto-fab CAI dyno results Roto-fab 1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 102 07-30-2016 08:21 PM
Vararam CAI Testing on Dyno at England Green Racing (Pix, Vids, RESULTS!!!) TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 113 01-05-2011 04:32 PM
Scrming's Airaid and Injen Dyno results... scrming Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 212 06-28-2010 04:28 PM
Camaro on the dyno today in Concord, NC! topgun1 Camaro Photos | Spyshots | Video | Media Gallery 6 03-19-2010 07:49 PM
SGOS's - L99 A6 Dyno results (after dyno tune) SGOS252382 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 48 07-27-2009 02:13 PM
