![]() Drives: L99 cyber grey Join Date: Jul 2009
L99 to LS3 conversion
I keep seeing references to the "L99 to LS3 conversion". Can someone tell me exactly what this is and what I expect as far as gains from it.
Don't Like it? Suggit.
Some minor changes in the heads and combustion, as I understand it. (Don't quote me on that)
The gains will hardly be worth the money it will take, much less the work.
"Tops off, tach up baby- loud and proud!" A Camaro lover from day one- 1996 3.8 V6 Camaro, to 1996 5.7 LT1 Camaro Z28, to the sold 2002 5.7 LS1 Camaro SS, and NOW, a [I]6.2 L99 VR 2SS/RS: XS Power stainless full exhaust, Airaid CAI, BMR drop springs and sways, custom tune by Cal Speed- 411rwhp |
I think it's mostly the cam.
That being said, it's pointless. An L99 _IS_ an LS3, just slightly tweaked (and it has VVT. Vtec, yo). If you want to make up the 26 hp and get rid of AFM, an ECU tune will pretty much do that.
A House Divided...
Getting rid of the AFM, what changes other than power would that have on the car?
God Bless Dawson
Drives: Synergy for my Daughter Join Date: Feb 2010
Your warrantee.
#6 |
If you want to wake a L99 up do the following. Get a cold air intake, get a ECM tune, get a tranny tune. And if you really want it to move when punching it get a stall convertor. I would not go inside the engine unless you have lots of money to fix things if they break.
After that still want more get a Maggie SuperCharger. |
#7 |
Drives: 2SS/RS Join Date: Mar 2010
Buy like 5,000 fireworks, strap them to the back of your car and set em off. The boost will make you fast.
#8 |
![]() ![]() ![]() Drives: 2010 IBM Camaro SS Join Date: Jun 2007
AFM 'tune out' alone wont increase your power. It probably would make no change at all except worse gas mileage. The AFM does not kick in when you are pushing hard on the gas.
#9 |
![]() ![]() ![]() Drives: 2010 Camaro SS Join Date: Oct 2008
The conversion is mainly for Cam changes.....
I did a Cam with a L99 TO LS3 Conversion and made 58 rwhp My boost on my TVS-2300 went from 8.5lbs to 5.5lbs with cam install..... My car has had the following deleted AFM,VVT,and DOD..... |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS IOM L99 Join Date: Jan 2010
not worth the money to do this and loose your warranty.
#11 |
For the record, I haven't done a tune. But the OP was asking about how to convert from 'L99' to 'LS3'. Some people don't like AFM for the sound (it doesn't bother me).
Honestly? L99s don't really have any trouble keeping up with LS3s. Both engines have run 12s. The L99 has low hanging fruit in the form of a tune, if you really want to increase your RWHP a bit (watch the warranty). 'Conversion' is really kind of specious. What's the point? The L99 IS an LS3, with some tweaks to support AFM and VVT. You want to make more power, say it that way.
A House Divided...
#12 |
![]() ![]() ![]() Drives: Transformers Edition Camaro 2SS/RS Join Date: Jan 2010
L99 to LS3 Conversion
From what I've read about the two cars.
Basically a cam, 8 lifters, and the compression is slightly different either from the heads or the pistons. I'd say the pistons, but it's not enought to really change anything. Then there is the variable valve timing & the computer reprogram. Your gains would be 26HP. It's not worth the effort. You could buy a cold air intake and some headers to to the same. I don't know about you folks, but I've gotten used to the AFM.
The Yellow Camaro Club
![]() http://www.camaro5.com/forums/group.php?groupid=128 Northern Massachusetts & Southern New Hampshire Camaro Club http://www.camaro5.com/forums/group.php?groupid=127 The mother of all supercharger questions thread ![]() http://www.camaro5.com/forums/showthread.php?t=77958 My 2010 Camaro Review ![]() http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442 2010 Transformer Edition Camaro L99 Auto ![]() ![]() ![]() Last edited by 2010 Bumblebee; 12-07-2010 at 04:04 AM. |
#13 |
What's VVT and DOD -- Sorry, I'm a novice on this stuff.
#14 |
How U Doin?
| LS3 engine specifications | Tran | Wiki | 3 | 10-06-2010 10:56 PM |
| LS3 vs L99 mods | ORANGE U NV | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 4 | 01-10-2010 09:45 AM |
| Solo Performance V8 Quantum Axle-Back Exhaust Kit for LS3 and L99 | GOINGSOLO2 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1 | 12-03-2009 02:01 PM |
| LS3 or L99 | AirBoyzT | 5th Gen Camaro SS LS LT General Discussions | 4 | 01-07-2009 05:22 AM |
| L99 engine specifications | Tran | Wiki | 0 | 10-19-2008 11:40 AM |
