![]() ![]() ![]() ![]() ![]() Drives: 2010 ZL550& 2021 C8 Z51 Join Date: Feb 2010
Installed my Dynatech LT and CAI today
Installed my LT and CAI today. Wow what a difference!! Headers suprisingly were very easy to install took only about 2.5 hours that is with removing the left header one extra time and crawling around on the ground.The CAI a little difficult because I had to cut down the tube to fit Maggie. not a real big deal though. Roads were wet today so did not have a chance to get on it at all. Hoping it clears up by morning so I can give a real spin.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS IOM L99 Join Date: Jan 2010
i would have thought the ZL would have come with headers and a good cai.that is surprising.i would love to have your car.
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
They can't deliver the car with headers due to emiision regulations. Car came with SLP Blackwing CAI w/K&N filter. It is just not that good, so I changed it.
I'm installing my Dynatech LTs soon and have a couple questions. How high off the ground did you have the car and did you need to take off the steering cloumn or oil dip stick?
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
#6 |
what do you mean emision regulations? as long as they had cats on the car with header it shouldn't have been a problem
my youtube
my facebook www.myspace.com/1djchampagne www.twitter.com/1djchampagne mods: borla long tube headers, borla atak catback, lingenfelter gt-9 cam, ported heads, ecs base kit running 11 psi on top end, 1" bmr drop spring, aam 3.70 gears, ported throttle body, 160* thermorstat, lethal racing tune 750/641 rwhp/rwtq |
#7 | |
I had the car about 15"-18" off the ground in the front only. The only problem I had due to height is I could not remove the left side complete. I had to take 1 of the bolts and loosen the other that connect the manifold and cats so that it would pivot. Yes I had to remove the steering column and the dipstick. Over all it was not very hard. Good luck you can PM me if you want I will answer anything I can. |
#8 |
I just know when you buy headers they typically state that they are "for off road use only". Plus this car has to be emmisson legal in 50 states. I don't think headers would pass California standards.I am sure someone out there can confirm if this is correct or not.
#9 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Some states are more picky than others and some don't have emission tests. For the picky states, you not only have to have cats but they have to pass a sniffer test and a visual test. If you physically move the cats from the OEM location, that is considered tampering with the emissions system and will be immediately failed, depite the sniffer test results.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
#10 |
ah ok, was wondering about it
my youtube
| Official 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 3656 | 11-01-2025 02:41 PM |
| Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 250 | 04-01-2014 11:40 AM |
| SS A6 or M6 faster?????? | MY2010SS | 5th Gen Camaro SS LS LT General Discussions | 275 | 05-20-2010 05:15 PM |
| Dynatech LT's with ADM CAI installed on my L99 Bumblebee | bumblebeecamaro | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 01-26-2010 01:39 PM |
| 12.68@113.67 with just LT and CAI | o2camaross | Dragstrip and Launch Techniques Discussion | 68 | 11-20-2009 06:01 PM |
