Old 04-17-2010, 11:15 AM   #1
Gunsmoke
wat?
Gunsmoke's Avatar
Drives: 2010 Chevy Camaro SS RS
Cam question
I'm thinking about pulling the trigger on my warranty and getting a cam done. First how much of a decrease in milage are you guys seeing and hows the reliability of a cammed motor as oppossed to a forced induction motor? Does the valvetrain have to be reset every so often? Thanks guys.
Gunsmoke is offline   Reply With Quote
Old 04-17-2010, 11:55 AM   #2
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
You will use the same factory lifters, pushrods, and rocker arms. You will be smart to change valve springs to match the cam lift and specs. You will also change out the cam gear, chain dampner, crank pulley bolt, cam bolts, and some other stuff. Plus, you must tune it. I assume you have a manual tranny. If automatic tranny then none of this applies. Good luck
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 04-17-2010, 12:19 PM   #3
Gunsmoke
wat?
Gunsmoke's Avatar
Yeah i drive an m6.
Old 04-17-2010, 03:31 PM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
ls3 = valve springs, pushrods are highly recommended.
cam bolt and crank bolt are TTY, so you will need new ones.
Will need a tune.
Depending on how aggressive your cam is, and which valve springs you get, will give you an idea on how often to replace valve springs.
and do yourself a favor and get a double valve spring, not a beehive
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 04-17-2010, 05:38 PM   #5
Gunsmoke
wat?
Gunsmoke's Avatar
i'm planning on having a shop do the work. any answers??
Looking for an LS3 cam suggestion - mild, slight idle lope, great driveability... Russell James Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 57 06-13-2013 01:48 PM
Hot Cam install question gearhead440 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 36 02-21-2011 12:23 AM
LS3 cam question 4xchamp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 05-04-2010 06:41 PM
Cam gear question 4xchamp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 04-16-2010 08:01 PM
L99 CAM SWAP - HELP! RickyTheStorm Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 03-26-2010 08:35 AM
