Old 04-18-2010, 08:19 PM   #1
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Installing LTs on East Coast
I feel like I'm missing something here...
From what I've read, installing long tube headers will throw a check engine light, or not throw the light, but still read a trouble code of some kind during an emissions test.
There's no way around this? No one on the east coast is legally running long tube headers in their daily drivers? I'd also find it hard to believe that everyone who may have LTs is swapping them out for stock every two years just to get their emissions test done.
It seems that here in north virginia they actually plug in and read codes, so even if the light isn't present, it wouldn't make a difference on the pass/fail because the code would still show something funny.
Reading more after posting this makes it seem that a tune may prevent the code as well as the light?
Ugh, wanna do long tubes so bad!!
Infern0 is offline   Reply With Quote
Old 04-18-2010, 08:51 PM   #2
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
It all depends on where you live, every state/county is different
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 04-18-2010, 09:03 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
The code is most commonly a cat efficiency code from physically moving the cats further back. It takes them longer to heat up, hense the code. Whether highflow cats pass the sniffer test remains to be seen. From what i've heard, it's not the sniffer test that's the problem, it's the visual test that it will fail since you moved them. Maybe someone can comment on them passing the sniffer test.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-04-2010, 08:55 PM   #4
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Any other takers? Looking for people in emissions controlled states who have done this specifically.
Old 05-04-2010, 11:05 PM   #5
Garys16SS
Garys16SS's Avatar
Drives: 2016 SS, BLACK, MANUAL
I live in Pennsylvania and are required to do an emission test once a year and I pass all the time with headers on my Vettes, Camaros, Vipers, etc., over my lifetime. No problems.
Garys16SS is offline   Reply With Quote
Old 05-05-2010, 12:42 PM   #6
Infern0
Bring It
Infern0's Avatar
Drives: In Between
So you have LTs with high flow cats? Do they hook up to your comp to read codes or do they just do the sniff test?
Old 05-05-2010, 12:49 PM   #7
HIGHOCTANE
HIGHOCTANE's Avatar
Drives: 2010 IBM 2SS/RS
In NC they do the OBDII scan....ie they hook up to the computer..I had no issues with Fords that were flash tuned and had LTs...now I did have a car that had an actual chip insead of a flash tune and it wouldn't pass..but a different tuner set that up so maybe it was something in the tune?
Doubtful it will pass without a tune,but there is one sre way to find out....
2010 IBM 2SS/RS Camaro (M6)
Previous rides:
2003 Twin Turbo Mustang Cobra(900 RWHP)
2004 KB S/C Mustang Cobra(700 RWHP)
2003 Mustang GT,Heads,Cam, N20 ect..
HIGHOCTANE is offline   Reply With Quote
Old 05-05-2010, 12:53 PM   #8
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Do you want to run cats or no cats?
Running longtubes is easy
If you want to run cats, everything is legit. run cats and hook up all 4 of your oxegen sensors in the proper place. You will pass everything with flying colors (i'm assuming the rest of your car is stock btw)
if you don't want to run cats. There are a few ways to get around this.
First problem is the "check engine light" That's an easy solution. They are called oxygen simulators or oxygen sims
Some counties have a visual inspection, where they will physically look for cats on your car. You can either install dummy ones, hope the inspector doesn't car and is a car guy, or swap out to catted mid pipes when you go get inspected.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 05-05-2010, 12:53 PM   #9
SK360
Drives: 2005 Pontiac GTO
All you need to do is have P0420 and P0430 DTC's set to No Error Reported by somebody with an HPTuners cable ($100 for credits to unlock the car on that cable) and then it will pass ODBII Scan no problem.... if you are planning on getting the car properly tuned after the headers then it can be taken care of then. 99% of aftermarket cats will trip the P0420 and P0430 codes as well due to being less efficient then the stockers.
**** o2 sims and the like, it takes 2 minutes to disable via software.
SK360 is offline   Reply With Quote
Old 05-05-2010, 12:54 PM   #10
danhr
BAMF SS
danhr's Avatar
doing that is an irreversible way to void his warranty though
voiding warranty just for headers... c'mon.
p.s.... i hate you... diaf
Stock Longblock
Old 05-05-2010, 01:00 PM   #11
SK360
Well installing LT's and not planning on having the car properly tuned is kinda dumb imo lol.
Old 05-05-2010, 01:08 PM   #12
danhr
BAMF SS
danhr's Avatar
We have warranties still on our cars booger.
Installing headers = easily reversed, won't effect warranty
Tune, of any kind = instant voidage of warranty.
If I told you, right now, you could have a 100,000 mile warranty on your car for ~10 rwhp, with 30,000 of that being bumper to bumper.... yeah...
and the car still makes lots of power without proper tune.
Stock Longblock
Old 05-05-2010, 01:09 PM   #13
thesnoopster
thesnoopster's Avatar
Hey Infern0, Im putting LT's with cats on mines probably later this month or next month (pending on how much my son will break me for his birthday gifts LOL) , there is a away around the system of the emmissions tests . But you do have some muscle cars that are running LT's and cats in the Nova area and I think everything is fine with them. I will be getting mines tuned right after I put them on.
2017 Camaro SS -"FIFTY"
Mods: "93 Octane"
Old 05-05-2010, 01:13 PM   #14
SK360
Warranty is for the birds... it's an LS motor, what's gonna break? (Besides the T6060 )
They aren't going to void your warranty on door lock actuators or window motors due to having a reflashed PCM
East Coast Car Transport Question Kocomo 5th Gen Camaro SS LS LT General Discussions 15 02-27-2020 07:16 AM
1 Time Only deal on a YSI Package from East Coast Supercharging East Coast Supercharging Forced Induction 9 02-26-2010 01:06 PM
East Coast Supercharging vinnyr Forced Induction - V8 35 01-27-2010 04:56 PM
Good camaro dealer on the east coast? fredzik 5th Gen Camaro SS LS LT General Discussions 12 10-20-2009 05:01 PM
